Need help with swirl marks - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
Thread: Need help with swirl marks
  1. #11
    Michael The Guz's Avatar
    Join Date
    Jul 2013
    Location
    Lawndale, CA
    Posts
    5,635
    Rep Power
    66
    Re: Need help with swirl marks
    Looks like you are going to need a DA to get the results you are after. You are at the limitation of what can be done by hand. Seeing as you are in the LA area, perhaps sign up for a thursday night garage.
  2. #12
    Registered Member Old Bear's Avatar
    Join Date
    Dec 2015
    Location
    San Juan Capistrano CA
    Posts
    728
    Rep Power
    13
    Here is link to next TNOG.
    https://meguiarsonline.com/forums/sh...-June-6th-2019
    It would be best to still respond to Nick's questions on pad used for your UC application.
    It looks like possibly the paint might have not been clean enough before beginning to compound.
    That can result in dirt and other contaminants getting into the pad and then cutting marks into the paint.
    When working by and, it is best to keep an even pressure across the pad to avoid "fingertip pressure" marks.
    The forums have a section on working by hand.
    https://meguiarsonline.com/forums/fo...orking-by-Hand
  3. #13
    Registered Member
    Join Date
    May 2019
    Location
    Los Angeles, California
    Posts
    9
    Rep Power
    2
    Quote Originally Posted by Nick Winn View Post
    Hi and sorry to see the excessive marring, this can happen at times when using a compound on more sensitive paints or darker colors. No need to worry, nothing permanent here. What type of applicator pad are you using to apply the product?
    I used a Meguiars foam foam pad applicator
    Any suggestions to getting them removed?
  4. #14
    Registered Member
    Join Date
    May 2019
    Location
    Posts
    9
    Rep Power
    2
    I used a Meguiars foam applicator pad
    What should I do to remove them?
  5. #15
    Join Date
    Dec 2015
    Location
    Posts
    728
    Rep Power
    13
    The Meguiar's 4 1/2 inch foam applicator pads come in 4 packs.
    https://www.meguiars.com/search?sear...fulltext=w0004
    Make sure you thoroughly clean the pad to remove any compound, before attempting to reuse it to polish.
    Alternatively, use a new unused pad from the four pack to polish.
    To compound or polish a full car, you would want to clean or switch pads frequently.
    This is also true for pads on a dual action polisher.
  6. #16
    Registered Member
    Join Date
    Nov 2020
    Location
    Romania,craiova
    Posts
    4
    Rep Power
    1
    it kind of happened the same to me as Blackfordfusion,i tried a test panel on an unwashed car,i cleaned a little just the test section/panel (black mercedes gle 2017) my car isn t affected by scratches,only swirl marks seen in very bright sun,anyways,i used UP first but didn t saw the difference so i used UC i would say that it removed most of the swirl marks,but now i only have very fine swirls,can you help please ?
    Maybe i need to use a product such as swirl x so it will not be as harsh as UC,i really don t want to remove much of the clear coat,any advice will help,thanks !
  7. #17
    Registered Member
    Join Date
    Nov 2020
    Location
    Romania,craiova
    Posts
    4
    Rep Power
    1
    Maybe i need to use a product such as swirl x so it will not be as harsh as UC,i really don t want to remove much of the clear coat,any advice will help,thanks!
    and if you would like i can provide some photos.
  8. #18
    Registered Member
    Join Date
    May 2019
    Location
    Posts
    9
    Rep Power
    2
    Quote Originally Posted by Alexanderrrr View Post
    Did you clay bar the car before I suspect this might have been why my car got swirl marks but process wise I ended up doing
    wash->clay->UC->UP->UW I got a DA polisher for this and all the swirls came out without a problem
  9. #19
    Registered Member
    Join Date
    May 2019
    Location
    Posts
    9
    Rep Power
    2
    Before: https://imgur.com/gallery/lEPlra6
    After: https://imgur.com/gallery/zTWgP0o Sorry I don’t have a close up
  10. #20
    Registered Member
    Join Date
    Nov 2020
    Location
    Romania,craiova
    Posts
    4
    Rep Power
    1
    Thanks for the reply ! No i did not clay the car,i have everything i need to remove the swirls(clay kit,UC,UP and wax)except a DA or rotary buffer,i did the test spot just to see what i need to use,but i ll guess it ll work great when i prep the car properly,guess i ll stick to hand polishing for now though
Thread Information
Users Browsing this Thread
Similar Threads
  1. Swirl marks help
    By Siboi95 in forum Detailing 101
    Last Post: Aug 9th, 2013, 07:29 PM
  2. Car with swirl marks
    By lazarc1204 in forum Detailing 101
    Last Post: Jan 13th, 2010, 02:32 PM
  3. Swirl Marks
    By GShulman in forum Detailing 101
    Last Post: Apr 11th, 2007, 06:59 AM
  4. Swirl Marks!!!!
    By MattCraze in forum Detailing 101
    Last Post: Aug 13th, 2006, 11:51 AM
  5. Swirl Marks?
    By djlockdown in forum Detailing 101
    Last Post: Aug 24th, 2005, 08:25 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
