Glass film - stripes issue
Results 1 to 7 of 7
Thread: Glass film - stripes issue
    Apr 2010
    Pennsylvania
    62
    I have this issue on all of my exterior glass when it rains and it poses the worst problem at night. It dosn't matter if it's winter or summer I have to put the defrost heat on to help with it. Have you seen this and what can I do? It's become a safety issue. I tried clay, etc. I think it might have come from using a touchless car wash, but I have taken my other cars through the same wash without any issues. I did read that a discontinued product called No Touch GS8 Auto Glass Stripper is good for this. Has anyone tried it? Help with this is appreciated! Thank you!
    Aug 2010
    Fairmont, MN
    76
    1,431
    24
    Re: Glass film - stripes issue
    No-touch is (was) a great product. A bit messy, but worked it did.
    As to what to use now, give "Bar Tenders Friend" a try. It's available a most grocery stores.
    There are probably other product out there, hope others will chime in with their ideas.
    Bill
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    40
    5,468
    63
    You may want to consider polishing the glass.
    Meguiar's makes the perfect clarity glass kit that can be found locally. If it does not work you may need to use a product like ceriglass. A polisher helps in these situations.
    39
    19,127
    237
    You say the defroster helps deal with it?
    Jun 2019
    NY
    5
    can I just suggest two simple tricks (1) Try to open your windows little bit and (2) try to on your fan in auto mode.
    I can tell you from my experience , It worked for me an might work for you as well.
    8,027
    91
    Using Clay on exterior glass will only remove bonded above surface contaminants present on the glass, so like others mentioned, "polishing" the glass is worth a try. As others mentioned, we have our Perfect Clarity Glass Care Kit, which includes our Perfect Clarity Glass Polishing Compound. You can also use an automotive paint compound, like our Ultimate Compound on the exterior glass as well, although, it is not going to work quite as well as our Perfect Clarity Glass Polishing Compound.
    800-854-8073 ext 3845
    May 2009
    Lynchburg, VA
    488
    15
    My guess, warming the glass with the defroster helps with whatever is causing his glare on the outside. I've had similar occasions.
  1. vinyl stripes
    By rdockery_3 in forum Detailing 101
    Last Post: Jun 23rd, 2011, 01:39 PM
  2. What to do about stripes
    By 04Mach1 in forum Detailing 101
    Last Post: Mar 12th, 2011, 06:33 AM
  3. NXT use on graphic stripes
    By ZOG in forum Meguiar's Consumer Line Products
    Last Post: May 14th, 2009, 07:57 AM
  4. 2 Questions, Glass issue and Fenderwell cleaning.
    By Dmitriy15 in forum Detailing 101
    Last Post: Apr 6th, 2008, 08:17 AM
  5. Pin stripes
    By kadidle77 in forum Tricks of the Trade!
    Last Post: Jan 26th, 2008, 05:23 AM
