Polishing in direct sunlight?
Results 1 to 7 of 7
Thread: Polishing in direct sunlight?
    Aug 2019
    Chicago ILLINOIS
    6
    Hello I
    Aug 2019
    Chicago ILLINOIS
    6
    Re: Polishing in direct sunlight?
    Hello I’m new to detailing and I wanted to get some haziness from my hood off ASAP for a car meet.I started by washing my car and going to work with meguiars ultimate compound with a microfiber hand pad.It was about 90 degrees out and sunny and the hood was hot to the touch.I don’t have a garage for a shade so I really didn’t have a choice.Anyways would this cause any problems to my paint? Clear coat?? After i was done polishing I noticed some streaks were left that i had to remove vigorously using a soft terry towel.
    (SORRY I KEEP GETTING CUT OFF FOR SOME REASON)
    8,062
    91
    Welcome & to get right to it, applying in the sun & to a hot surface can cause the product to flash dry on the paint, making it difficult to get off. I would recommend re-applying in the shade, and also with a soft foam applicator pad, it will be less aggressive than a microfiber applicator pad.
    That will get you going since you are in a rush & we can go from there on your goals/expectations for the car. Speaking of what are you working on?
    800-854-8073 ext 3845
    Aug 2019
    Chicago ILLINOIS
    6
    Would it cause scratches hand polishing with a microfiber pad on a hot hood? Or could it damage the clear coat? I think I might have cause damage now as the hood is pretty scratched up.I will take it to a professional.
    Jan 2007
    Rochester Hills, Michigan
    606
    20
    Quote Originally Posted by Ichiglo_vq View Post
    Going over it again with a foam applicator should clear things up.
    Dec 2015
    San Juan Capistrano CA
    643
    Make sure your surface is clean before polishing.
    Make sure the polishing pads stay clean.
    As DrumDan says try a foam applicator to see if it clears up any light marring left by the MF pad.
    Do you have a 10 f.t pop up that you can use for shade?
    8,062
    91
    I agree with above 2 comments. Repeat application with a soft foam wax applicator pad.
  1. Polishing Paint in Direct Sunlight?
    By USMC11 in forum Machines - The Dual Action Polisher
    Last Post: Feb 5th, 2011, 12:25 PM
  2. M-21/2.0 in direct sunlight - no surprises
    By Don in forum Meguiar's Professional Lines - Mirror Glaze & Detailer
    Last Post: May 2nd, 2009, 01:48 PM
  3. Direct Sunlight
    By Tech_Greek in forum Detailing 101
    Last Post: Dec 16th, 2007, 09:01 PM
  4. direct sunlight
    By detailerrex in forum Detailing 101
    Last Post: Mar 30th, 2006, 07:20 AM
  5. Waxing in direct sunlight!??!!?
    By MandarinaRacing in forum Detailing 101
    Last Post: Aug 6th, 2005, 08:07 AM
