Can't find 1000-2000 discs
Results 1 to 10 of 11
Thread: Can't find 1000-2000 discs
    Sep 2019
    Mt. Vernon NY
    8
    Who carries wettable (probably not the right word, but the ones you use with water) discs for grits 1000-2000? I see only the black sheets in those grits in local auto stores.
    Dec 2015
    San Juan Capistrano CA
    664
    Re: Can't find 1000-2000 discs
    Detailing stores carry wet sanding disks for dual action sanders. They carry them in flat and padded.
    Here is a link to one online detailing shop and their #M TriZact disks.
    https://www.detailing.com/store/cata...=asc&q=trizact
    Here is a video with Jason Rose, Kevin Brown and Larry Kozilla.
    https://www.youtube.com/watch?v=BgCmrGMhvss
    It does not take long (seconds) to burn through clear and paint.
    No need to ask me how I know.
    Stay away from edges, body lines where you can cut through quickly.
    Also spend time searching and watching additional resources.
    Sep 2019
    Mt. Vernon NY
    8
    Thanks, Old Bear. . Great video, better step-by-step than others I've viewed. It's my first time spraying. It was too hot in my garage, and the clear coat came out sandy-looking because I couldn't keep a wet edge, rougher than in the video, where they start at 1500. Would you suggest a rougher grit for smoothing down the texture first? I've done the whole hood, so hand-sanding isn't practical.
    And, yes, I know now I should have practiced on a small spot first.
    Do I have to wait before applying Meguiars Ultimate Compound? I sprayed on 9/3.
    Dec 2015
    664
    There are 4 parts to this video.
    You should be able to link to the other videos at the end of each one.
    Dec 2015
    664
    I would not go courser than 1500.
    Check with the manufacturer of the paint on how long it needs to set up and how long it will be off gassing.
    Sep 2019
    Mt. Vernon NY
    8
    Many thanks!
    Sep 2019
    Mt. Vernon NY
    8
    Can't find part 3. Could you recommend a similar video?
    Dec 2015
    664
    I should have said four steps and not four parts.
    Here is another resource. This is Mike Stoops with images, notes and at least one video full of tips on wet sanding. This is very good. Make sure to find the image of hand sanding that is really a video link.
    http://www.meguiarsonline.com/forums...Advanced-Class
    Sep 2019
    Mt. Vernon NY
    8
    Thanks. This is the first mention of 3000 I've seen. It's going to make the rest of my car look like s---.
    Dec 2015
    664
    You can also get 5,000 grit discs.
    Did you notice in Jason Rose/Kevin Brown Video yesterday that they showed a soft interface pad?
    Did you notice how Mike Stoops hand sand video shows flat hands on sanding pad and tight soft strokes?
    Did you see his image showing how "NOT" to hand sand?
    Got to keep those fingers from making pressure lines.
  1. Can't find ColorX but can find lots of Meguiar's 06
    By Blueline in forum Detailing 101
    Last Post: Sep 22nd, 2014, 06:55 AM
  2. Ungrit Sanding Discs & Finishing Discs
    Last Post: Apr 14th, 2010, 06:39 PM
  3. My 1000's photo post MEG'S BIG RIG
    By SHYNEMAN123 in forum Show Off Your Latest Detail Work
    Last Post: Aug 20th, 2009, 07:57 PM
  4. Touch up spot - moving from 1000 to 2000 to 2500/3000 - Think it'll work?
    By dhahlen in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Dec 26th, 2008, 08:34 PM
  5. Removing 1000 grit wetsand with PC
    By mikespine in forum Detailing 101
    Last Post: Oct 4th, 2008, 06:34 PM
