Baked on wheel cleaner
Results 1 to 10 of 17
Thread: Baked on wheel cleaner
    Sep 2018
    Las Vegas
    Used Hot rims all wheel and tire wheel cleaner for the first time. It dried out completely and stained my aluminum wheels badly. Probably my fault, as wheel was warm.
    Any advice on best removal product/tools.
    Started with drill polishing head with Mother's wheel polish. Working, but slow process.
    Maybe 0000 steel wool?
    Other suggestions?
    Thanks in advance ��.
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    40
    5,506
    64
    Re: Baked on wheel cleaner
    Welcome to MOL.
    Are the factory or aftermarket wheels?
    Sep 2018
    Las Vegas
    Aftermarket HRE wheels.
    Jul 2013
    Lawndale, CA
    40
    5,506
    64
    I believe HRE wheels are aluminum with no clear coat finish. The easy way to tell is to take some metal polish and if the applicator turns black then it is bare metal. If it does not then treat it like paint. Polishing should restore the finish. Try with an applicator (ie microfiber towel, applicator, foam applicator) first. You should not need steel wool.
    If they are bare metal then hot rims all wheel is not the correct wheel cleaner. It could stain the finish. The aluminum wheel cleaner is what you are looking for. I believe Ultimate All Wheel Cleaner is fine.
    Check out these links on wheel care
    https://meguiarsonline.com/forums/sh...-December-2017
    https://meguiarsonline.com/forums/sh...are-Simplified
    Sep 2018
    Las Vegas
    Thanks for all the info Guz. They are indeed bare metal as the applicator turns black.
    I actually used the Hot Rims Wheel And Tire Cleaner.
    And just ordered a gallon of D143 Non Acid Wheel And Tire Cleaner. Is that one safe for bare uncoated wheels?
    Says that it's not safe for uncoated wheels as well.
    I've used other wheel cleaners in the past on these wheels, and never encountered any issue.
    Perhaps it's the surface heat that worsened the outcome?
    Jul 2013
    Lawndale, CA
    40
    5,506
    64
    Unfortunately it is not safe for your wheels. It is the pro/bulk version of Hot Rims All Wheel & Tire Cleaner.
    You would want the aluminum wheel cleaner which is available over the counter in a blue bottle. Ultimate All Wheel Cleaner works as well. See 8 mins of the link I posted.
    Unocated wheels are wheels that do not have a clear coat. Polished wheels are not clear coated unless they are factory aluminum wheels. Since your wheels turn the applicator black they are uncoated.
    Sep 2018
    Las Vegas
    Very interesting indeed. Just tried the D143 on a cool wheel, and no staining. Just was cautious of dwell time.
    Shame there's no gallon product for uncoated wheels that's low on acidity/PH like the Ultimate All Wheel.
    Do you know of such?
    Sep 2018
    Las Vegas
    Will a high dilution ratio (1:4) of D143 on a cool wheel perhaps be safer?
    Any other gallon size cleaner recommended?
    8,193
    92
    Quote Originally Posted by Noamtasini View Post
    Meguiar's Professional Detailer D1801 Wheel & Paint Iron Decon would be only gallon option for uncoated aftermarket wheels.
    Meguiar's D1801 Professional Wheel & Paint IRON DECON
    800-854-8073 ext 3845
    Sep 2018
    Las Vegas
    Thanks.. But at that price I'll do an APC and some soap and water. ��
  1. Meguiars Ultimate All Wheel Cleaner vs Meguiar's Hot Rims Wheel Cleaner
    By j2ee in forum Meguiar's Consumer Line Products
    Last Post: Jul 16th, 2019, 10:04 AM
  2. Replies: 4
    Last Post: Nov 6th, 2011, 05:54 PM
  3. Replies: 4
    Last Post: Oct 21st, 2009, 06:18 PM
  4. Hot Rims All Wheel Cleaner or Aluminum Wheel Cleaner?
    By bzimmer in forum Meguiar's Consumer Line Products
    Last Post: Jul 30th, 2009, 06:49 PM
  5. Baked on wheel grime, is there anything that will remove it?
    By 99GrandTouring in forum Detailing 101
    Last Post: Jun 9th, 2004, 04:10 PM
