NXT Glass Cleaner
  • NXT Glass Cleaner
    Has Meguiar's Perfect Clarity Glass Cleaner replaced NXT Glass Cleaner? I can't seem to find NXT Glass Cleaner anymore. Thank you
    Bill Strobel
    aka theamcguy
    Owner Independent Towing
    Fayetteville, NC
    Do It Right or Don't Do It At All.
    Re: NXT Glass Cleaner
    Yes
      Was it just a name change or was there an update in the formula. By the way Meguiar's makes several different glass cleaners, what is the difference between them? Are some better at some tasks than others? Are some better on removing outgassing film vs removing road film?
      Bill Strobel
      aka theamcguy
      Fayetteville, NC
        Hmm, I think the Perfect Clarity and the Detailer Line one are the main two... The Detailer Line one is a concentrate, so you can buy in bulk and mix it with water yourself. It is probably a bit cheaper, and I guess you could mix it a bit stronger if wanted.
        Other than that, I dont know much difference.
        I seem to have had to use a damp cloth with some detergent on it to help with outgassing/oil from defroster recently on my car... dont know why.
        For the road grime, I also clay the outside of the windows a couple times a year. You can also use something like Ult. Compound with a cloth on the glass if needed. Then the glass cleaner after.
