Clay barred using ceramic hybrid as lubricant
Results 1 to 3 of 3
Thread: Clay barred using ceramic hybrid as lubricant
    Oct 2019
    Chardon ohio
    Just joined forum. I clay bar my cars every spring and fall and decided to use ceramic hybrid as the lubricant. Washed the car, rinsed and did not towel dry. Sprayed hybrid on a panel and then clay barred - making sure to pass over the whole panel. Then hosed as you would when using hybrid when waxing the car. Worked great !! Made sure each panel was wet prior to spraying hybrid and claying. Took only about 20 minutes to clay bar and wax car.
    Jan 2011
    Southern California
    3
    Re: Clay barred using ceramic hybrid as lubricant
    Interesting idea. Did you feel the need to be liberal with the product in order to get the lubricity you needed for the clay? I find that most HCW users are spraying WAY too much of the product on a panel. The Meguiar's how-to videos show something like 2 or 3 sprays max per panel.
    Oct 2019
    Chardon ohio
    Quote Originally Posted by trom120 View Post
    I sprayed just enough to spread over the surface. 2 to 3 sprays worked out fine
  1. How to use Meguiar's NEW Hybrid Ceramic Wax!
    Last Post: Jun 5th, 2020, 12:37 PM
  2. Hybrid ceramic wax
    By Drmilr in forum Meguiar's Consumer Line Products
    Last Post: Aug 17th, 2019, 05:22 PM
  3. Hybrid Ceramic wax..
    By 02Rodeo in forum Detailing 101
    Last Post: Aug 12th, 2019, 02:23 AM
  4. Hybrid Ceramic Wax, NXT Tech 2.0 Wax, etc.
    By cruise4two in forum Detailing 101
    Last Post: May 2nd, 2019, 11:00 PM
  5. New Hybrid Ceramic Wax
    By oh_well in forum Customer Service Hotline
    Last Post: Mar 12th, 2019, 11:58 AM
