Help! Compounding car and noticed paint has been blown in sometime in the past!
Results 1 to 7 of 7
Thread: Help! Compounding car and noticed paint has been blown in sometime in the past!
  1. #1
    Registered Member Icarus's Avatar
    Join Date
    May 2014
    Location
    Ontario, Canada
    Posts
    16
    Rep Power
    6
    I started the correction on my car today and noticed a spot on the drivers side front fender and a spot on the ds front and rear for has been painted in the past! You can see the outline of it on all three panels. They are pretty big, 3"wide or more and up to almost the length of the one door!
    If I continue with Meguairs compound and an orange pad will it fade out more, or will I make it worse?! I have a heavier cut yellow pad to try if need be too...
    Please help!
  2. #2
    Join Date
    May 2014
    Location
    Ontario, Canada
    Posts
    16
    Rep Power
    6
    Re: Help! Compounding car and noticed paint has been blown in sometime in the past!
    I gave up for the night and didn't do the drivers side yet till I figure out more what to do.
  3. #3
    Join Date
    Sep 2010
    Location
    Irvine, CA
    Posts
    7,947
    Rep Power
    90
    I see the area in the picture you are referring to. What exact defect are you trying to address?
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
    800-854-8073 ext 3845
  4. #4
    Join Date
    May 2014
    Location
    Ontario, Canada
    Posts
    16
    Rep Power
    6
    The outline of the paint blow in (diagonally downwards from l-r.)
  5. #5
    Join Date
    Sep 2010
    Location
    Irvine, CA
    Posts
    7,947
    Rep Power
    90
    Ok thank you for clarifying. If this is a blend within a panel, if you continue, it actually can make it "worse" & more apparent. Can you try to capture the defect in another picture from another angle?
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
  6. #6
    Join Date
    May 2014
    Location
    Ontario, Canada
    Posts
    16
    Rep Power
    6
    I tried to get another pic, but wasn't able to get it to show (only have my phone to try with.)
    I've got the car completely compounded and polished except for these three panels, so need to get these done.
  7. #7
    Registered Member
    Join Date
    Sep 2008
    Location
    west branch, michigan
    Posts
    98
    Rep Power
    12
    i might be seeing what looks like taped off for paint then the tape and masking removed for clear. the way the lines arent straight,though throws me off a bit.
    if you take your finger nail across that line can you feel it? either way that looks like some pretty bad orange peel in the clear.
    i dont know if the lines will come out even with color sanding but the orange peel will.
    the good thing there is the clear will have a thicker mil than factory so theres less chance of sanding through clear if/when its sanded.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Red paint turned white after compounding.
    By GMG in forum Detailing 101
    Last Post: Jun 11th, 2012, 12:40 PM
  2. C200 another 4 days paint correction M95 compounding
    By bstp in forum Extreme Makeover Before & After Pictures
    Last Post: May 22nd, 2012, 05:08 AM
  3. Touch Up Paint, And Compounding?
    By soulless in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Aug 10th, 2011, 03:20 AM
  4. noticed hazing on new paint job
    By masterkyle in forum Detailing 101
    Last Post: Dec 16th, 2010, 10:46 AM
  5. blown away!
    By dietoremain in forum The Break Room
    Last Post: Feb 22nd, 2010, 04:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
