Meguiar's M27 PRO Hybrid Ceramic Sealant - Page 9
Page 9 of 11 FirstFirst 1234567891011 LastLast
Results 81 to 90 of 101
Thread: Meguiar's M27 PRO Hybrid Ceramic Sealant
  1. #81
    Jan 2008
    21
    Re: Meguiar's M27 PRO Hybrid Ceramic Sealant
    I have a 2018 Tacoma that I clayed and then used Ultimate wax on about 2 months ago and periodically using P&S Beadmaker to enhance gloss. I want to use this sealant. So will I now have to use the Meguiar surface prep to remove what I have used now? Thanks
  2. #82
    Aug 2008
    Norcal
    5
    12
    What have you guys found is the best way to apply M27, by hand with a foam or microfiber application pad or DA with a black foam pad or microfiber pad? I am currently prepping my surface and will be applying M27 this weekend.
  3. #83
    May 2009
    Lynchburg, VA
    512
    17
    Quote Originally Posted by thedawg View Post
    I would think you're fine just to clay the surface completely before applying the M27.
    Quote Originally Posted by accordhybrid View Post
    If you have a DA I can't imagine you would ever go back to applying wax/sealants by hand. Would you? My method is with the black pad and a DA. Be warned, it takes some getting used to. You'll want a consistent pattern that you use to cover an area, kind of like cutting grass, you don't just go wild and run the machine all over the area. It WILL disappear, especially if you have a light color.
  4. #84
    Aug 2008
    Norcal
    5
    12
    Quote Originally Posted by HCAD View Post
    Thank you for your response. I would prefer to apply by DA, but for some of the reasons you mentioned and my first time using it; I wasn't sure if applying by hand would be better. This is being applied to a silver car. I'll take a shot at it with the DA and a black foam pad.
  5. #85
    Sep 2004
    23
    16
    I used a DA both a black pad and a foam applicator for smaller areas. Simply clayed over a fairly fresh coat of Klasse AIO. Worked a treat on a dark color (Nori Green) It’s been very rainy since and the beading is intense.
    Very easy to apply and remove.
  6. #86
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    41
    5,538
    64
    The surface prep may or may not remove what is already on the surface. It may degrade it. A light polish will definitely remove what you have.
    Would you have issues using the surface prep and then sealing? No other than you might not get the max longevity out of it whatever that may be in your environment.
    It is personal preference. Try both ways and see what method you prefer.
  7. #87
    Aug 2008
    Norcal
    5
    12
    I ended up applying my hand. I did half the hood by hand and the other half by machine. I felt I had more control and could keep a better eye on where I spread the sealant. Thank you all for your suggestions.
  8. #88
    Feb 2015
    SW Florida
    174
    7
    i just use a microfiber pad. 4 dots per panel and go around the car with the bottle in my hand. Takes no time at all. I do have a Meguiars DA, along with both the MF and Foam pads, but unless i'm doing a correction, i don't use it. Too much work getting it all out, and the extension cable.. Making sure the cable is not in the way.. This stuff goes on so easy, by the time i've unraveled the extension cable, i've already got half the car done by hand if using a hand held microfiber pad.
    Be warned / or happy depending on how you like things to work, this stuff literally disappears after a few mins. So keep track of panels you've already buffed off. Even on a black car, i had to look twice sometimes to say where's it gone ? lol Its very very easy to work with. Didn't give me any issues, and is probably the easiest product i've ever used. Most importantly it gave me that proud feeling after looking at the reflections. I gave it the slick test, and its as slick as any of the products out there who are renowned at being the 'slickest'
  9. #89
    Aug 2017
    Santa Clara, CA
    28
    3
    Anybody have any opinions how many layers for this stuff? Or is the old Meguiars motto of "Just two layers to ensure even coverage" still apply?
  10. #90
    Apr 2004
    48
    17
    Quote Originally Posted by Brian Hann View Post
    Technically any of our washes would be fine, but if you choose a wash with wax in it like our Ultimate Wash & Wax you will likely knock down the water beading effects of the Hybrid Ceramic products you have on the surface. So sticking with something like our Gold Class Wash would make sense.
    Nick,
    Can I use Shampoo Plus followed by M27 PRO Hybrid Ceramic Sealant and then M799 PRO Hybrid Ceramic Bead Booster as needed on my wrapped car?
    Thank you.
  1. Meguiar's Hybrid Ceramic Wax
    By Nick Winn in forum Meguiar's 2019 New Products
    Last Post: Jun 1st, 2020, 09:25 AM
  2. Meguiar's M799 PRO Hybrid Ceramic Bead Booster
    By Nick Winn in forum Meguiar's 2020 New Products
    Last Post: May 21st, 2020, 02:31 PM
  3. How to use Meguiar's NEW Hybrid Ceramic Wax!
    Last Post: May 6th, 2020, 11:36 AM
  4. Meguiar's Hybrid Ceramic Wax now available in Canada
    By Nick Winn in forum Company & Forum Announcements
    Last Post: Jul 12th, 2019, 08:21 AM
  5. How to: Meguiar's Hybrid Ceramic Wax - New Video Feb 2019
    By Nick Winn in forum Meguiar's Videos
    Last Post: Feb 7th, 2019, 04:59 AM
