Meguiar's Detailer RTU - Iron Removing Spray "Clay"
Results 1 to 10 of 17
Thread: Meguiar's Detailer RTU - Iron Removing Spray "Clay"
    8,924
    101
    Meguiar's Iron Removing Spray "Clay" quickly removes iron-based contaminants & industrial fallout, while also dissolving below surface contaminants such as rail dust & iron oxides. This decontamination helps prepare the surface for faster paint correction & better results!
    • Removes above & below surface contamination
    • Improves Paint Smoothness
    • Changes Color as it Activates
    • Dissolves Embedded Iron Contamination
    Product Number: DRTU200232
    Size: 32 fl oz
    MSRP: $19.99
    800-854-8073 ext 3845
    Rob bowlerr's Avatar
    Aug 2017
    Alamogordo, NM
    41
    54
    4
    Re: Meguiar's Detailer RTU - Iron Removing Spray "Clay"
    So is this basically D1801 with some slickness to make it a clay lubricant?
    8,924
    101
    Quote Originally Posted by bowlerr View Post
    Yes exactly, but not as potent strength as D1801 Wheel & Paint IRON DECON. This is also not designed for wheels.
    Aug 2017
    Alamogordo, NM
    41
    54
    4
    Understood. Thanks Nick.
    Registered Member pcfxer's Avatar
    Aug 2006
    329
    18
    But this "replaces" clay right? I currently spray on TRIX and bought IRON DECON to use instead, of course, one should always follow up with a quick clay bar to doubly check that the surface is fine but I'll buy this when my new gallon of IRON DECON is used up.
    2015 Fiat 500 Abarth.
    2011 Nissan Sentra SE-R Spec-V using AMSOIL synthetics. Best 1/4 mile: 14.959 (sold)
    8,924
    101
    Quote Originally Posted by pcfxer View Post
    This does not replace clay, but works like a "spray clay" since it removes both above & embedded ferrous specific contaminants.
    Aug 2006
    329
    18
    Thanks Nick.
    Apr 2020
    Denver, CO
    Is this safe to use on a professionally installed ceramic coating, such as Ceramic Pro? Will is remove any of the coating? It looks like it is nearly ph neutral.
    Jan 2008
    21
    14
    So do u need to even use clay then? I read u just spray wait a bit and wipe off ? Thanks
    Aug 2019
    Usa
    You can use it as regular iron remover spray on rinse off or with their pro clay only (not from kits)as a clay lube. Even pro clay will eventually break down after using a while with product
  1. Professional Detailer vs. retail "home"/"enthusiast" products comparison...
    By spraycleaner in forum Meguiar's Professional Lines - Mirror Glaze, Detailer, PRO Hybrid Ceramic & Other
    Last Post: May 22nd, 2017, 04:26 AM
  2. any upgrade for "D15601 Synthetic X-Press Spray Wax"?
    By mikek753 in forum Meguiar's Professional Lines - Mirror Glaze, Detailer, PRO Hybrid Ceramic & Other
    Last Post: Oct 29th, 2013, 12:52 PM
  3. Big "A" Detailing 08 Civic Removing Overspray By Hand Compounding on You Tube
    By AndrewBigA in forum Show Off Your Latest Detail Work
    Last Post: Aug 22nd, 2011, 07:24 AM
  4. Keep your spray bottles full, my "overfill" method
    By DualActionDetail in forum Tricks of the Trade!
    Last Post: Apr 25th, 2010, 07:39 AM
  5. difference between "professional" and "detailer" lines
    By CarbonBlack in forum Meguiar's Professional Lines - Mirror Glaze, Detailer, PRO Hybrid Ceramic & Other
    Last Post: Jan 4th, 2008, 06:43 AM
