UFF to prevent new exhaust system from rusting quickly?
Results 1 to 10 of 10
Thread: UFF to prevent new exhaust system from rusting quickly?
    May 2006
    Suburban Washington DC
    203
    17
    Tried an experiment today after replacing the exhaust system. Sprayed it with UFF. Wonder if it will keep it from developing surface rust any quicker than it normally would.
    Dec 2015
    San Juan Capistrano CA
    719
    12
    Re: UFF to prevent new exhaust system from rusting quickly?
    " Sprayed it with UFF."
    Just pointing out that the application method for Ultimate Fast Finish includes to spray onto the provided black microfiber application towel, Then to the finish.
    UFF comes in an aerosol can, which uses a propellant to pressurize the can to expel product through the nozzle onto the towel.
    Propane is the propellant for UFF.
    I know that I would likely fire up as soon as possible to listen for rattles and yes, to hear the new sounds.
    You are probably much smarter than I.
    Hitting a hot exhaust with propane could result in "running around with hair on fire".
    That's not always a good look.
    So let's add this caution from the UFF box front label:
    DANGER! EXTREMELY FLAMMABLE
    LIQUID AND VAPOR. VAPORS MAY CAUSE
    FLASHFIRE. CONTENTS UNDER PRESSURE
    Dec 2015
    719
    12
    Well, the last edit did not save.
    Just pointing out that the application method for Ultimate Fast Finish includes to spray onto the provided black microfiber application towel, Then use the towel to apply the finish.
    May 2006
    203
    17
    That's why I said, "experiment."
    Apr 2007
    US
    1,121
    25
    I don't think you would have any issues with it exploding because of the propane propellant, in my opinion. and it would be useless in protecting your exhaust system. I would think the system would get hot enough to gas off the UFF fairly quickly. Most replacement exhaust replacement systems are either galvanized or already has some rust protection, so you are probably wasting money using UFF on it. Good thought though. I am trying to determine some alternate use for my bottle of UFF as I am not a fan of the stuff for it's intended purpose.
    8,629
    98
    We do not recommend this application. We would also agree with other's comments that it will likely flash off very quickly due to the heat. Plus raw metal is not the same make up as a modern clear coat paint system.
    800-854-8073 ext 3845
    Registered Member snozan's Avatar
    Jul 2016
    Sweden
    43
    225
    7
    First off, to prevent a exhaust from rusting is to protect the welds. It's 99% of where the exhaust rust.
    Use something like this: https://www.pinterest.se/pin/112027109486491403/
    If you are really afraid about your exhaust to rust, buy a stainless
    Registered Member Jeepster04's Avatar
    Jul 2006
    Eastern Kentucky
    1,253
    27
    Quote Originally Posted by snozan View Post
    This. Only issue I found with using stainless is I've yet to find anyone that can weld, let alone weld stainless.
    May 2006
    203
    17
    It's just a cosmetic thing. Wan't it look like new for a few months until I sell it.
    Jul 2016
    Sweden
    43
    225
    7
    Quote Originally Posted by Jeepster04 View Post
    Just out of curiosity, why would you wanna weld? Just clamp it
    Quote Originally Posted by atikovi View Post
    Buy som heat paint, and just paint the welds. A few months won't hurt it
  1. New Member: Hello! Rusting rock chip prompted Joining!
    By busickpg in forum Introduce Yourself - New Members
    Last Post: Oct 5th, 2017, 10:29 AM
  2. Replies: 10
    Last Post: Jul 28th, 2008, 08:40 PM
  3. How to fix RUSTING chips and scratches?
    By mgray in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Jul 28th, 2008, 06:40 AM
  4. Help Quickly!
    By bradipock in forum Detailing 101
    Last Post: Feb 23rd, 2008, 01:52 PM
  5. Just saying hi quickly
    By oOgerryOo in forum Introduce Yourself - New Members
    Last Post: Jan 22nd, 2008, 07:45 PM
