Jewel/Burnish
  • Jewel/Burnish
    Does Meguiars have any products to really refine an already corrected vehicle to make it pop?? Something with a very fine abrasive. Have found other jeweling waxes/polish from other manufacturers but always try to stay in the Meguiars family
    Re: Jewel/Burnish
    Hi Drmilr, are you working by hand or machine? If machine, Meguiar's M210 Ultra Pro Finishing Polish is now our most advanced finishing polish & although we do not use the term "jewel", it is designed to deliver what you described, ultra fine, very refined abrasive, to deliver maximum clarity, depth, "pop", gloss, prior to applying protection like a wax, coating, paint protection film, etc. This product is best applied with a machine, like a dual action polisher with a foam finishing or foam polishing pad.
    More information can be referenced here:
    https://meguiarsonline.com/forums/showthread.php?67028-Meguiar-s-Professional-M210-Ultra-Pro-Finishing-Polish
    Hope this helps & feel free to post further questions.
      Re: Jewel/Burnish
      Other options are our M205 Ultra Finishing Polish & our Ultimate Polish Pre-Waxing Glaze. Especially if working by hand, our Ultimate Polish Pre-Waxing Glaze will likely deliver best results, since it is best suited for hand use. Again, for our latest & most advanced polish in this cleaner/polish / finishing/polish category, it would be our M210 Ultra Pro Finishing Polish.
        Re: Jewel/Burnish
        It will be machine applied so I will take a look at the 210. Can you move directly to a sealant from there without worrying about any oils or fillers interfering with it. Thank you.
          Re: Jewel/Burnish
          Yes absolutely. It is not required to strip oils/residue from a polish prior to using any Meguiar's sealant. At this time only our M788 Deep Crystal Ceramic Paint Coating requires special preparation, an application of our M122 Surface Prep Spray. However, although not required, if one prefers, they can use a product like our M122 Surface Prep Spray after a product like M210 & prior to an application of a sealant like our M27 PRO Hybrid Ceramic Sealant. This reason this would be done would be primarily to check true finish of paint & ensure nothing is hiding.
