Wet Sanding and Ultimate Compound
Results 1 to 3 of 3
Thread: Wet Sanding and Ultimate Compound
    Apr 2007
    US
    1,121
    25
    Need to repair a couple of rock chips which, when filled, plan to wet sand them level with 2000 grit. Will a DA tool (the Meguiars DA that fits on the end of a drill) and the little red pad that comes with it, plus Ultimate Compound get the 2000 dulling effect out? I will follow it up with Ultimate Polish. Thanks.
    Jan 2007
    Rochester Hills, Michigan
    613
    20
    Re: Wet Sanding and Ultimate Compound
    It should, but might take a couple passes.
    I've had success removing 1000 grit with it on a green hex pad on a medium paint hardness. Machine was a porter cable 7424xp
    Apr 2007
    US
    1,121
    25
    Thank you.
  1. Minor Swirl Marks after Sanding/Compound/Polish/Wax
    By locorecto in forum Detailing 101
    Last Post: Aug 23rd, 2018, 08:34 AM
  2. Replies: 9
    Last Post: May 7th, 2012, 04:03 AM
  3. Replies: 2
    Last Post: Sep 3rd, 2011, 07:16 PM
  4. Wet Sanding Scratches and Applying Ulti. Compound and Polish
    By Broseph in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Sep 3rd, 2011, 08:40 AM
  5. Ultimate Compound vs. Wet Sanding Marks
    By Mister B in forum Show Off Your Latest Detail Work
    Last Post: May 28th, 2009, 06:40 AM
