Will Dawn remove UP residue?
Results 1 to 8 of 8
Thread: Will Dawn remove UP residue?
    Apr 2007
    US
    1,119
    25
    Planning to use Dawn to remove Ultimate Polish residue (polishing oils). Will it remove it? I want nothing on the clear coat at all and don't want to go out and buy a pile of IPA, when I have lots of Dawn under the kitchen sink. Thanks.
    Jan 2007
    Rochester Hills, Michigan
    613
    20
    Re: Will Dawn remove UP residue?
    If you have any glass cleaner around the house, that should work. Not sure about Dawn.
    Apr 2007
    US
    1,119
    25
    Hmmmmmm...glass cleaner. Never thought of that. I understand Dawn will removed wax so that was my plan if it removed the polishing oils in Ultimate Polish. However, I would think Windex would definitely remove polishing oils and leave nothing behind. Thanks for the reply.
    Jan 2007
    613
    20
    Most panel wipes are alcohol based, which is essentially glass cleaner.
    I remember Mike Phillips saying that glass cleaner was already at proper dilution ratios for to use in panel wipe applications.
    Jun 2014
    Sault Ste Marie Ontario Canada
    82
    6
    i have found the foaming glass cleaner works better and sticks where you spray it. that way you can let it sit and soak for a minute to let it work before wiping/washing it off.
    Feb 2020
    Dallas
    I asked this same question to a Megs customer service rep, and they recommended a brush and a product such as Dawn. To be honest, it was an asswhip. Then I tried the "school eraser" method and that was much easier with less worry about Dawn running down on the paint of the car. I followed up with Megs Back to Black plastic trim after I erased off the residue. Came out great.
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    41
    5,536
    64
    Dawn/dish soap leaves leaves surfactants behind so it could make one think that the surface has been cleaned when it is masking. With that said polishing oils are not very durable.
    Apr 2007
    US
    1,119
    25
    Thanks everyone. I am going to go with glass cleaner. Appreciate the help.
  1. APC to remove white residue on trim
    By Vettefan in forum Meguiar's Professional Lines - Mirror Glaze & Detailer
    Last Post: Aug 14th, 2013, 05:08 PM
  2. Remove #205 residue at tape lines?
    By rqk in forum Detailing 101
    Last Post: Jun 8th, 2010, 06:46 PM
  3. How do I remove egg residue?
    By Minimimi in forum Detailing 101
    Last Post: May 22nd, 2009, 12:01 PM
  4. Replies: 19
    Last Post: Mar 14th, 2009, 06:41 AM
  5. Replies: 2
    Last Post: Feb 19th, 2007, 11:53 AM
