Will Dawn remove UP residue?
Results 1 to 8 of 8
Thread: Will Dawn remove UP residue?
  1. #1
    Registered Member Blueline's Avatar
    Join Date
    Apr 2007
    Location
    US
    Posts
    1,121
    Rep Power
    25
    Planning to use Dawn to remove Ultimate Polish residue (polishing oils). Will it remove it? I want nothing on the clear coat at all and don't want to go out and buy a pile of IPA, when I have lots of Dawn under the kitchen sink. Thanks.
  2. #2
    Join Date
    Jan 2007
    Location
    Rochester Hills, Michigan
    Posts
    634
    Rep Power
    20
    Re: Will Dawn remove UP residue?
    If you have any glass cleaner around the house, that should work. Not sure about Dawn.
  3. #3
    Join Date
    Apr 2007
    Location
    US
    Posts
    1,121
    Rep Power
    25
    Hmmmmmm...glass cleaner. Never thought of that. I understand Dawn will removed wax so that was my plan if it removed the polishing oils in Ultimate Polish. However, I would think Windex would definitely remove polishing oils and leave nothing behind. Thanks for the reply.
  4. #4
    Join Date
    Jan 2007
    Location
    Posts
    634
    Rep Power
    20
    Most panel wipes are alcohol based, which is essentially glass cleaner.
    I remember Mike Phillips saying that glass cleaner was already at proper dilution ratios for to use in panel wipe applications.
  5. #5
    Registered Member
    Join Date
    Jun 2014
    Location
    Sault Ste Marie Ontario Canada
    Posts
    82
    Rep Power
    7
    i have found the foaming glass cleaner works better and sticks where you spray it. that way you can let it sit and soak for a minute to let it work before wiping/washing it off.
  6. #6
    Registered Member
    Join Date
    Feb 2020
    Location
    Dallas
    Posts
    1
    Rep Power
    1
    Quote Originally Posted by Blueline View Post
    I asked this same question to a Megs customer service rep, and they recommended a brush and a product such as Dawn. To be honest, it was an asswhip. Then I tried the "school eraser" method and that was much easier with less worry about Dawn running down on the paint of the car. I followed up with Megs Back to Black plastic trim after I erased off the residue. Came out great.
  7. #7
    Michael The Guz's Avatar
    Join Date
    Jul 2013
    Location
    Lawndale, CA
    Posts
    5,609
    Rep Power
    66
    Dawn/dish soap leaves leaves surfactants behind so it could make one think that the surface has been cleaned when it is masking. With that said polishing oils are not very durable.
  8. #8
    Join Date
    Apr 2007
    Location
    US
    Posts
    1,121
    Rep Power
    25
    Thanks everyone. I am going to go with glass cleaner. Appreciate the help.
Thread Information
Users Browsing this Thread
Similar Threads
  1. APC to remove white residue on trim
    By Vettefan in forum Meguiar's Professional Lines - Mirror Glaze & Detailer
    Last Post: Aug 14th, 2013, 05:08 PM
  2. Remove #205 residue at tape lines?
    By rqk in forum Detailing 101
    Last Post: Jun 8th, 2010, 06:46 PM
  3. How do I remove egg residue?
    By Minimimi in forum Detailing 101
    Last Post: May 22nd, 2009, 12:01 PM
  4. Replies: 19
    Last Post: Mar 14th, 2009, 06:41 AM
  5. Replies: 2
    Last Post: Feb 19th, 2007, 11:53 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
