Product Recommendation instead of 3M Perfect It for new paint
Results 1 to 3 of 3
Thread: Product Recommendation instead of 3M Perfect It for new paint
    Registered Member cturboaddict's Avatar
    Aug 2011
    Near the Arch
    3
    Looking for some product guidance.
    My 66 Mustang is getting out of the paint booth this week. Metallic Silver base with 3 coats of clear on top.
    There's a bit of orange peel that needs to be addressed and polished out.
    My painter recc using the 3M Perfect It kit, but I'm not huge on the costs or performance of 3M products.
    I plan to cut it down with 1500 wet, then 2000 wet before polishing.
    What products would be best to work through on the Compounding, Polishing, Swirl Elimination from the Meguiars line?
    For what it's worth, I'm running the Porter Cable DA polisher with Hex Logic pads.
    Thanks for the help!
    Jan 2007
    Rochester Hills, Michigan
    634
    20
    Re: Product Recommendation instead of 3M Perfect It for new paint
    Not sure how hard your clear is, but I was able to remove 1000, and 1500 on single stage with M100 and green hex pads. Never had any luck with the orange or yellow..
    I'd consider picking up some microfiber pads for that task. M100 cuts really hard though. They have the new M110, but I haven't tried it yet.
    You might even want to pick up a rotary to cut the sanding marks quickly, and polish with M205 on the PC.
    With the newer Megs systems, you only really need the M100 and M205, as the M205 is considered a polish/swirl remover
    Sep 2008
    west branch, michigan
    112
    14
    megs M100 with a twisted wool pad on a rotary. orange pads on my da works great with m100,too but more time consuming. follow up with m205 polish with an orange pad on my pc 7424
    if youve never used a rotary, its not bad. the mistake most people make is starting with high rpms. thats not necessary. you can start with a lower rpm to get the feel and work the rpm up as ya learn how it works.
  1. Product recommendation
    By cbuckley00 in forum Detailing 101
    Last Post: Jun 5th, 2017, 08:02 AM
  2. Need Product Recommendation Assistance...
    By Jbirk in forum Detailing 101
    Last Post: Jun 16th, 2014, 01:08 PM
  3. Product recommendation
    By VanCityWW in forum New Product Suggestions
    Last Post: Oct 15th, 2013, 09:06 AM
  4. product recommendation.
    By gerson200 in forum Meguiar's Consumer Line Products
    Last Post: May 1st, 2012, 11:50 AM
  5. Product recommendation for a speed boat
    By McCune in forum Meguiar's Marine/RV/Flagship Lines
    Last Post: Jun 2nd, 2010, 08:02 AM
