Help: Tape line after using Ultimate Compound
Results 1 to 5 of 5
Thread: Help: Tape line after using Ultimate Compound
  1. #1
    Registered Member
    Join Date
    Feb 2020
    Location
    New Jersey
    Posts
    27
    Rep Power
    1
    Hi all,
    So I just taped off a section on the hood to focus on the area that I want to attack a minor scratch. I am using a DA with Chemical Guy white foam pad. I did a couple of passes with Meguiar Ultimate Compound. After I removed the blue painters tape, I notice an outline of the tape has formed. I hit the area with M210 on a finishing pad a few times, but the outline is still visible at certain angle.
    Did I hit the area too hard with the compound? While I taped it off, I didn't really limit my passes strictly within the taped area, I did let the pad go over and beyond the area I taped off, but I can't imagine that's how I imprint the outline.
    It is minor and I can only see it if I look for it, but you know how it is if you are OCD. Any suggestions on how to remove the outline?
    I tried to capture it on camera, but it just wouldn't pick it up.
    Thanks.
  2. #2
    Join Date
    Jan 2007
    Location
    Rochester Hills, Michigan
    Posts
    631
    Rep Power
    20
    Re: Help: Tape line after using Ultimate Compound
    This happens sometimes, when people tape off a section, and polish inside the square. What happened is that the paint is now lowered in that section.
    You might be able to polish it out, but since paint is already thin, you might want to consider living with it.
    Many detailers who use tape, only do so to protect trim because of this type of event occurring.
  3. #3
    Registered Member
    Join Date
    Feb 2020
    Location
    New Jersey
    Posts
    27
    Rep Power
    1
    Thanks.
    I am thinking about just hitting that area a few quick pass with Ultimate Compound again. It just surprised me as I didn't think Ultimate Compound was that aggressive. The car has never been polished by DA before, all previous "correction" was done by hands, so I can't imagine the paint is too thin at this point.
  4. #4
    Registered Member
    Join Date
    Aug 2019
    Location
    Usa
    Posts
    10
    Rep Power
    1
    Can’t you just do the rest of the panel so it is all even
  5. #5
    Registered Member
    Join Date
    Feb 2020
    Location
    New Jersey
    Posts
    27
    Rep Power
    1
    Most likely. Maybe not the entire panel, just the area affected and hopefully, it will be gone once a few passes are done.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Need advice on fixing tape line from touchup.
    By pakamper in forum Detailing 101
    Last Post: Jun 19th, 2019, 03:12 PM
  2. Replies: 3
    Last Post: Feb 6th, 2015, 01:53 PM
  3. Auto Paint Tape Line Elimination
    By kna4977 in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Aug 23rd, 2012, 04:38 PM
  4. Polishing Tape Line?
    By seanbreaux in forum Detailing 101
    Last Post: Nov 14th, 2008, 11:56 AM
  5. Sanding a clear coat tape line
    By BabyBigfoot in forum Sanding Automotive Paint - Hand/Machine
    Last Post: May 13th, 2006, 03:13 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
