Hi all,
So I just taped off a section on the hood to focus on the area that I want to attack a minor scratch. I am using a DA with Chemical Guy white foam pad. I did a couple of passes with Meguiar Ultimate Compound. After I removed the blue painters tape, I notice an outline of the tape has formed. I hit the area with M210 on a finishing pad a few times, but the outline is still visible at certain angle.
Did I hit the area too hard with the compound? While I taped it off, I didn't really limit my passes strictly within the taped area, I did let the pad go over and beyond the area I taped off, but I can't imagine that's how I imprint the outline.
It is minor and I can only see it if I look for it, but you know how it is if you are OCD. Any suggestions on how to remove the outline?
I tried to capture it on camera, but it just wouldn't pick it up.
Thanks.
Thanks.
