Hi all,
I am wondering which product works better (or should be used) on painted plastic trim. My car's A pillar is covered by a plastic trim that has a gloss black finish. Initially, I buff the trim using a Chemical Guy white pad with Scratch X 2.0. The result was quite good. However, my OCD really kicked in and I wanted to see if Ultimate Compound would improve the finish. I followed up with M210 after Ultimate Compound.
I am extremely shocked that it actually made it worse than using Scratch X 2.0 alone. I totally understand that you need to use the right products for the right material. Is this a case using the wrong product? I didn't think it would matter since the plastic is painted, but based on the result, it seems to suggest so.
Here is a side-by side shot (It is probably needless to say that the right side looks much better and is the Scratch X 2.0 side):
I will hit it with Scratch X 2.0 again hoping I can bring the crisp back.
Thanks.
Thanks.
