Running out of old polishing compounds, what should I replace them with?
Results 1 to 9 of 9
Thread: Running out of old polishing compounds, what should I replace them with?
    May 2006
    Suburban Washington DC
    186
    16
    My go-to product is M105 at least for horizontal surfaces that have the most imperfections and I might use M83 for vertical panels that aren't too bad. After that I go directly to UFF. I also have #9 Swirl Remover that I haven't used much since the first two products are all that are required. I use a DA with a yellow foam pad.
    1) What's the latest product like M105 that gives maximum defect removal without requiring a second product to further refine its results? Looking at M110, M101, M100, M85. What's the difference between those four products and M105? The bottles all say maximum aggressiveness.
    2) What's the latest product like M83 that is a step less aggressive than M105 for areas that need less intense work? Looking at M205, Mirror glazes #1 #2 #4.
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    5,563
    64
    Re: Running out of old polishing compounds, what should I replace them with?
    Go with M110 and M210. M205 is nice to have as well as it is quite versatile. You would be all set with all 3 of these products.
    May 2006
    186
    16
    OK, so 110 is just an improved 105? It won't need a second pass with a finer product?
    Jul 2013
    Lawndale, CA
    5,563
    64
    M110 is the newest compound designed for a dual action polisher. A little less cut but a better finish. The best parts are a longer working time and no dusting.
    To answer your second question, it depends on the hardness of the paint. Your test spot will be the way to go. As I mentioned having M205 around is good as it is quite versatile. The thing about M205 is that it does not always finish well on softer paints. This is where M210 fits into the picture. One would be set with these three products.
    Sep 2008
    west branch, michigan
    110
    if ya use a rotary, M100 rocks with a twisted wool pad.
    Jul 2009
    Salt Lake City
    537
    25
    I've not used M110. I find that Ultimate Compound is much better than M105. No dusting and it does not flash as fast. It has almost the same cut as M105. Again, I've not tried is against M110 but it beats M105 hands down.
    8,396
    94
    I would agree, my go to nows are Ultimate Compound, D300 D/A Microfiber Correction Compound, M100 Pro Speed Compound, and M110 Ultra Pro Speed Compound M210 Ultra Pro Finishing Polish. I tend to use 110/210 the most.
    800-854-8073 ext 3845
    Sep 2008
    110
    nick, i himmed and hawwed about that M100 for quite some time. i was blown away when i finally used it. i dont find much need for polishing after but still do it.
    8,396
    94
    Quote Originally Posted by tomsteve View Post
    Awesome! I agree, i was blown away the first time I used it also. 06 LS430 single stage paint, soft paint, was spinning a large stroke d/a paired with our DMC6 D/A Microfiber Cutting Disc, wiping off the compound & literally seeing 0 ticks, & almost 0 haze. Was blown away personally myself also! M210 is just as impressive 2!
    Thanks for sharing!
  1. Want to know the DAT Compounds and SMAT Compounds
    By solution in forum Meguiar's Professional Lines - Mirror Glaze & Detailer
    Last Post: Aug 30th, 2016, 01:04 PM
  2. Running board.
    By Bruce Devilbiss in forum Detailing 101
    Last Post: Jun 5th, 2012, 03:17 PM
  3. Polishing foam pads- when to replace
    By ripple_effect in forum Detailing 101
    Last Post: Jul 22nd, 2010, 03:35 PM
  4. Detailing Novice Tries Rubbing & Polishing Compounds
    By BRODA in forum Meguiar's Consumer Line Products
    Last Post: Feb 19th, 2010, 09:29 AM
  5. Running out of GC Trim Detailer - Replace or Upgrade?
    By dcn in forum Meguiar's Consumer Line Products
    Last Post: Mar 5th, 2008, 09:57 AM
