wheels and tires
for cleaning how does the iron decon or citrus power plus cleaner compare to the d143 wheel cleaner? i will be using the iron decon for ceramic prep and citrious for interior
cermanic coating prep
what soap is recommended to use before iron decon?
then i would correct the paint
then clean the oils with m122 or a ipa. not sure which one ill go with
after cermanic coating
what soap is reccommended?
then m799
glass
also if anyone has info on removing water spots from glass
what do you use to wipe down glass cleaner to leave streak free? ive really only had success with newspaper. but ive only used windex. i dont know if that makes a difference
any info would be appreciated thanks
then m799
glass
