Hybrid Ceramic Liquid Wax vs Hybrid Ceramic Wax (spray) vs Ultimate Fast Finish?
Results 1 to 8 of 8
Thread: Hybrid Ceramic Liquid Wax vs Hybrid Ceramic Wax (spray) vs Ultimate Fast Finish?
    Jan 2020
    USA
    20
    I know using all 3 products would get me the best protection, but if I were to use only one product, what would get me the best protection of the three following options?
    Applying "Meguiar’s Hybrid Ceramic Liquid Wax G200416" with DA action polisher about once every 3 months
    OR
    Applying "Meguiar's Hybrid Ceramic Wax" G190526" by jusy spraying after washing and rinsing and before drying about 8 times every 3 months?
    OR
    Applying "Utimate Fast Finish" about once every 2 months? (since it's less effort that pulling out the DA polisher I could apply a little more often)
    Thanks!
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    5,639
    66
    Re: Hybrid Ceramic Liquid Wax vs Hybrid Ceramic Wax (spray) vs Ultimate Fast Finish?
    It is going to be up to personal preference. Do you want to venture into the latest technology with SiO2 or do you want to stay with polymers.
    You can use HCLW and maintain it with HCW as well. By the way one does need a machine to apply HCLW. It can be done by hand just fine.
    Jan 2020
    USA
    20
    Thanks for the reply! I do want to venture into the lastest SiO2 technology. I added UFF because I still have like half a can left. Not sure if I should use still use it or discard it if the technology is too old/inferior.
    I kinda have had good luck with the HCW (spray, blue bottle) but after watching several youtube videos, it doesn't seem to perform as well as some of the competitors products, looking closer at other Meg's SiO2 products, it seems my best best in terms of best protection and durability would be M27 instead? Applying around every 3-6 months with DA to the whole car and then wipe off?
    One advantage of only applying with DA/finishing pads would I'd be touching the paint less during maintenance, since I could dry with just leaf blower after the wash, instead of rubbing the dry towel with overall less lubrication while trying to apply HCW spray, I know I can also do touchless application which I do like half of the time but seems to need double of the product for half the performance vs application with towel in dry or a little wet surface
    Jul 2009
    Salt Lake City
    538
    26
    Quote Originally Posted by vwite View Post
    Why do you think using three is better than one or two? Is it only because you think using more products affords more protection?
    According to the manufacture, using any of the methods you mention affords the same protection. As far as protection goes, you are probably really looking at water beading, UV protection and protection from light fall out and bird droppings.
    Personally, if I had to pick one that I would follow, I'd eliminate using Hybrid Ceramic Way as a spray on and power wash off application. Way too many variables to know if it is being evenly applied. Personally, I use it every once in awhile diluted with water and in a spray bottle.
    If I had to choose, I'd used Liquid Wax applied every 3 months, hands down. What I'd also do is wash once a week and refresh with FF. FF takes about 5 minutes to apply after a wash. If you can find it at Pepboys it is about $5 right now.
    Jan 2020
    USA
    20
    Quote Originally Posted by tcope1 View Post
    [/COLOR]
    Actually, I may be wrong on this, I read on other threads that it is better to apply ceramic wax on a "clean" surface, after claying, polishing and without anything else on the paint to achieve better bond and best durability, however I've also read that "ceramic wax" needs to be the top layer if I want the best water beading and "self-cleaning technology", which is what I'm really looking for since it rains here almost every day. My car almost always have that "just washed" look because water just flies off the car as I start driving while all other cars are full of rain marks/water spots.
    So if anything, according to the Meg's rep, the order should be
    1. Ceramic wax as foundation
    2. True wax or another sealant more oriented for gloss (optional)
    3. Ceramic wax on top for beading and "self-cleaning"
    He mentioned putting for example UFF over a ceramic wax would ruin the water beading.
    I don't think UFF is oriented to gloss, it's more like also for protection so not sure if I should keep using it in the middle or just stop using it, as you say it only takes 5 minutes to apply but it's still more risk of introducing new swirls, I just ordered a MM "Crazy Pile" though which seems it will be a extremely safe towel for this.
    [/COLOR]
    Haha I actually have a similar method when I do the "touchless application", I realized it takes me around 20-25 trigger presses to cover the whole car, according to how Meguiars show it in the videos, for example around 3-4 sprays for a medium hood. So I spray the ceramic wax (blue bottle) around 25 times inside a small 64 oz pump sprayer, then add around 32 oz of water and shake and spray way more evenly all around the car, then rinse off with pressure washer.
    It seems to work to some degree, I do immediately notice some boost in beading and it becomes easier to dry the whole car with the leaf blower, however as I mentioned previously, it seems to take double the product for half the performance. But I take the extra cost to avoid introducing new swirls while rubbing towel.
    I know it's more expensive now, but my first bottle was around $9 with a coupon at Walmart when it just came out and the bottle had last me quite a few applications, the cost per application seems to be less than a buck on this first bottle.
    I know with M27 would be around $7-$10 per application, but I hope it lasts longer.
    Jul 2013
    Lawndale, CA
    5,639
    66
    You are way overthinking this. You already know you want to venture into new technology. So use the HCLW and as I mentioned and there are videos on the Meguiar's channel stating one can use the HCW spray as maintenance or the the ceramic detailer. SiO2 products are going to offer what you are looking for. UFF is not going to meet that criteria.
    Jan 2020
    USA
    20
    Thanks Guz, what about using M27 instead of HCLW?
    It seems best option is stop using UFF and just keep two steps:
    1. M27 every few months (quick polish with ultimate polish or M205, then apply M27, both with DA polisher)
    2. Try to maintain with touchless, and almost effortless application of Hybrid Ceramic Wax spray after every couple of washes, this only adds like 6 minutes of spaying diluted solution all over the paint surface with pump sprayer and then second rinse with pressure washer
    Jul 2013
    Lawndale, CA
    5,639
    66
    You may want to sign up for this and get more information. Should be a good thing to watch.
    https://meguiarsonline.com/forums/sh...f-7-6&p=595256
  1. Meguiar's Hybrid Ceramic Liquid Wax
    By Nick Winn in forum Meguiar's 2020 New Products Introduction Thread
    Last Post: Dec 25th, 2020, 05:49 PM
  2. Ultimate Liquid vs. hybrid ceramic
    By pcray1231 in forum Detailing 101
    Last Post: Jul 20th, 2020, 04:04 PM
  3. Using Hybrid Liquid Ceramic Wax as a topper..
    By 02Rodeo in forum Detailing 101
    Last Post: Apr 2nd, 2020, 04:00 PM
  4. Replies: 3
    Last Post: Mar 9th, 2020, 09:36 AM
