DIY deionized water
Results 1 to 8 of 8
Thread: DIY deionized water
    Jun 2011
    Huntington Beach
    5
    DIY deionized water
    Has anyone built a DIY deionized water system? somewhat stationary? for home use.
    Thanks,
    NT
    8,950
    101
    Re: DIY deionized water
    Quote Originally Posted by nordictom View Post
    Thanks,
    NT
    I would recommend checking out the Obsessed Garage Facebook Group. There are a lot of D.I/Pressure Washer Home Builds on there.
    800-854-8073 ext 3845
    Jun 2011
    Huntington Beach
    5
    I will check it out.
    Thanks!
    Aug 2014
    anaheim hills, ca
    98
    7
    I tried to build one using (2) carbon filters and a salt ionized exchange using standard home depot products with a couple specialty items from autogeek. Though I realize this isn't a DI water solution I wanted to "save money". Needless to say it only kind of worked and I resulted in buying a CR Spotless (which has now been modified to hold more resin). I buy resin once per year which is quite expensive. It may be beneficial to look into an exchange program through a company like PureTec if you absolutely have to have DI water. A much cheaper solution is go to a rinseless water solution using DI water from Target or your local grocery store (usually $0.89/gallon). When I did my cost analysis using a pressure washer attached to CR spotless, it cost me about $10 to was a car due to resin loss/exchange.
    Aug 2014
    anaheim hills, ca
    98
    7
    nasioc has a good tutorial on a DIY DI water filtration system using (2) pentek filters
    https://downtime.nasioc.com/forums/s....php?t=2832232
    Jun 2011
    Huntington Beach
    5
    Thanks for the info TR. I haven't heard of PureTec, but will look into it. I had a DI tank from a Large water filtration provider. Originally it started ok great, but after the company was sold, bought & sold again the quarterly billing increased (I had a contract) & they would return my checks, "undeliverable", multiple address changes to the billing department, I told them to get the tank out of here. I really don't want to go down that road again.
    Jun 2011
    Huntington Beach
    5
    Quote Originally Posted by twisty roads View Post
    I found that write up in my searching. I found a business about 2 miles from my house in Fountain Valley that will build a DI tank ( so I can purchase it) for around $300. I am going to stop by and check out the equipment & quality of the parts this week.
    NT
    8,950
    101
    Let me know if you do not mind too because I agree with the CR Spotless set up resin goes fast & is expensive.
  1. QUESTION: Spot Free Water De-Ionizer filter system to eliminate water spots
    By LucidShineAutoDetailing in forum Detailing 4 Dollars
    Last Post: Apr 27th, 2020, 04:50 PM
  2. Replies: 20
    Last Post: Aug 1st, 2015, 11:54 AM
  3. HELP!!water etching (type 2 water spot) maybe more
    By xgwsx in forum Detailing 101
    Last Post: Jul 3rd, 2014, 03:54 PM
  4. Reducing water spots with water filter
    By EPHIOS in forum Hot Topics & Frequently Asked Questions
    Last Post: Aug 10th, 2010, 11:24 AM
  5. Replies: 6
    Last Post: Mar 23rd, 2006, 04:11 PM
