Haze on single stage paint from Meguiars 83 and MF..HELP?
Results 1 to 10 of 14
Thread: Haze on single stage paint from Meguiars 83 and MF..HELP?
    Jul 2020
    Ventura, CA
    6
    I have a 64 Plymouth that was repainted in Hemi Orange Pearl before I got it so I am not sure when exactly. I tried to remove some scratches, that I now figured out were from my MF, with 83 and a low quality MF. Yeah I know, dumb. Well my scratches turned into a giant circle that looks gray from certain views. After reading for hours I decided to use 83, but this time with an orange correcting pad by Griots. The paint doesn’t seem to get damaged like with the MF, but my haze like circle won’t go away. I have tried by hand as well as with a Dewalt orbital DWP849X. I have tried Ultimate compound as well as Show Car glaze with no luck . I am more frustrated that I caused more damage than I am with the damage haha. I feel like I have “tried everything”, but I’m pretty sure that is my lack of knowledge on this speaking. Please help me out!
    8,793
    99
    Re: Haze on single stage paint from Meguiars 83 and MF..HELP?
    Quote Originally Posted by Scanch View Post
    Welcome to Meguiar's Online. It sounds like this would be cleaned up with a finishing polish like our M205 Ultra Finishing Polish & a foam polishing or finishing pad.
    Also, if you are just getting back into this, a dual action polisher would be much easier to get great results, compared to your DWP849X, which is categorized as a rotary machine. Very different machines.
    Hope this helps. Feel free to ask/post as many additional questions/comments as you would like.
    800-854-8073 ext 3845
    Jul 2020
    Ventura, CA
    6
    I am willing to buy the m205 if you can please explain to me why that would work and not the 83. What is in it that would fix my problem? I have read I should be able to use the same product I caused the damage with to clear it up, as long as I use a foam pad. Clearly that doesn’t seem to be working for me, but I do notice much less paint coming off as I work...and it isn’t making it worse so that is a plus. Thank you for reaching out. The customer service line isn’t working and I was thinking I was out of luck.
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    5,633
    66
    Nick makes a great point on the machine. Even the best rotary users can't finish the paint hologram free. Thus Nick's recommendation to get a dual action polisher to finish out the paint haze and hologram free. M205 on a DA with a polishing pad should finish out just fine.
    Jul 2020
    Ventura, CA
    6
    I gave it another shot with the 83 and rotary. This time I used much less product on the pad and did slower passes. I noticed a drastic difference. I have read about holograms, but that hasn’t been my issue....so far. I have read and been told to go to a DA. This rotary was gifted to my father years ago and for obvious reason(big and heavy) it got zero use. I tend to be cheap and like to use what I have around. Starting to realize being cheap around single stage paint isn’t too intelligent. I really appreciate you reaching out. I am clearly out of my concert zone on all this.
    Jul 2013
    Lawndale, CA
    5,633
    66
    Haze is also a byproduct of an aggressive pad, abrasive liquid, tool and paint hardness.
    Dec 2015
    San Juan Capistrano CA
    728
    Frequently pearl paints are three stage, rather than single stage.
    They normally have a base coat, followed by a pearl coat that is comprized of mica crystal flakes of varying colors and mixed in with a clear or colored clear. Then that is topped by one or more clear coats.
    Do you know which single stage paint you have installed?
    Some of the single stage pearls are designed to not provide a high gloss.
    Here is an example of orange pearl low gloss.
    https://shop.thecoatingstore.com/Sun...IT-PGCO430.htm
    Jan 2007
    Rochester Hills, Michigan
    661
    21
    Any chance you can post a picture of the grey circle.
    Microfiber disc is probably the last thing one would want to use on a rotary buffer.
    I fear that the paint manage been burned.
    What speed did you use? What was your technique like (pressure, rate of movement of the buffer, etc)?
    Dec 2015
    728
    This article by RoushStage2 will help you upload images from your PC to your Gallery on the Meguiars Online Forums servers.
    It also will show you how to add images to your posts.
    https://meguiarsonline.com/forums/sh...ghlight=images
    Jul 2020
    Ventura, CA
    6
    I show people and they can’t see it so I don’t think a picture would work. I have to get a few feet away at a certain angle to get the light to reflect perfect to barely see it. Family thinks I am crazy haha OCD for sure. I am using a finishing foam pad. 1000 rpm with light pressure and I would say at medium speed(if high speed would be as fast as I could do it). All the damage was caused by hand with a terrible quality microfiber. Wiped a new cd with the towels I was using and it scratched it instantly. The paint is so soft I could rub that MF without compound, just soap and water, and it will start to cause the same gray like haze. Appreciate you responding.
  1. Single Stage Paint
    By mis3 in forum Detailing 101
    Last Post: Aug 17th, 2013, 01:57 PM
  2. Single stage paint.
    By 97miata in forum Detailing 101
    Last Post: Jul 26th, 2010, 10:24 PM
  3. What is a Single Stage Paint?
    Last Post: May 27th, 2010, 11:49 AM
  4. Red single stage paint is so fun
    By Tuck91 in forum Extreme Makeover Before & After Pictures
    Last Post: Oct 2nd, 2009, 08:10 PM
  5. Single Stage red paint
    By Mysta Joe in forum Detailing 101
    Last Post: Oct 27th, 2008, 10:50 AM
