Hybrid Ceramic Detailer uses
Results 1 to 8 of 8
Thread: Hybrid Ceramic Detailer uses
    Oct 2019
    Australia, Canberra
    85
    Hi all
    I recently purchased a bottle of hybrid ceramic detailer.
    I’m have trouble figuring out where this sits in my regime? If my car is dirty I’d rather wash it to minimize swirls (soft black paint). I currently use hybrid ceramic spray wax as my LSP. If I’m looking to top up my coating I’d rather just use the fully fledge HCW. The difference in price here isn’t that great.
    Is the sweet spot using it as a drying aid maybe every 2 weeks? If so, how do you all do this? Ie rinse car, spray with HCD, dry car, use clean towel to buff?
    Where are you all using this in your routine?
    Also, I mainly use gold class for maintenance washes and nxt gen for a detail pre wash.
    I’m assuming either of these shampoos are ok for washes with HCW coatings?
    Perhaps megs are formulating a shampoo for their sio2 range!
    Thanks all!
    40
    19,251
    239
    Re: Hybrid Ceramic Detailer uses
    Yeah... I've used it for bird droppings and things of course. And a drying aid, and follow up to waterless wash.
    And yeah, the regular soaps are fine to wash with.
    Oct 2019
    Australia, Canberra
    85
    yeah bird droppings is one use actually?
    What is your technique for using it as a drying aid? I’ve been researching and everyone does it differently!
    If you already have a strong coat of HCW on, would using HCD compromise that?
    Oct 2019
    Australia, Canberra
    85
    Tried to delete or edit the above post but must be too late!
    40
    19,251
    239
    Yeah, a detail spray or a waterless wash spray is good for bird droppings... just be sure to use a good spray, so it is quite lubricated when wiping it up.
    As for drying, generally I would give a gentle rinse to get most of the water off, then go around once generally drying everything, and then once around again with a dry towel giving a light mist and drying everything up.
    The Hybrid Ceramic products should all work together well.
    Oct 2019
    Australia, Canberra
    85
    I used HCD yesterday as a drying aid in a similar manner that you suggested above and it streaked quite badly. In order to remove streaking i had to really buff on the 2nd go around when drying which isn't ideal for me with a black car with soft paint. I should have sprayed some water on to remove the streaking but i was already in the drying process so i just kept going with the drying towel.
    In terms of it being a 'drying aid' - I'm sure there are cases where it is used successfully to serve this function, and perhaps i just used it wrong, but it didn't 'aid' the drying process for me.
    In terms of gloss, I used it as a drying aid on one half of the car to compare. It did add some additional gloss but it wasn't really noticeable. To be honest, I find that if i have a decent coat of HCW on and use Gold Class it comes up pretty glossy after a wash anyway. Perhaps the gloss of the side with the HCD on it will last longer (as with protection durability), i'll keep an eye on it.
    40
    19,251
    239
    I'd say spray pretty light...these new products seem to smear a bit when used heavily...thats my only real tip... but if they do smear (the waxes or the detailer), just leaving it out in the sun for a day seems to even it out.
    Oct 2019
    Australia, Canberra
    85
    Yeah good point. I'd say i sprayed maybe 3-4 triggers on the bonnet (hood) for example.
    Interesting tip to leave it in the sun! I find streaking with HCW seems to go with my next wash anyway
  1. Replies: 7
    Last Post: Jul 6th, 2020, 06:55 PM
  2. Hybrid Ceramic Detailer
    By Sprzout in forum Detailing 101
    Last Post: Jun 4th, 2020, 12:45 PM
  3. Meguiar's Hybrid Ceramic Detailer
    By Nick Winn in forum Meguiar's 2020 New Products Introduction Thread
    Last Post: May 4th, 2020, 09:43 PM
  4. Hybrid Ceramic wax..
    By 02Rodeo in forum Detailing 101
    Last Post: Aug 12th, 2019, 02:23 AM
  5. New Hybrid Ceramic Wax
    By oh_well in forum Customer Service Hotline
    Last Post: Mar 12th, 2019, 11:58 AM
