Sap removal.
  • Sap removal.
    I have some thick, sticky sap spots on my wife's white 2017 Toyota Sienna. The spots are about 1/4" in diameter and are raised.
    I tried washing with warm water to soften, plastic razor blade, bug/tar remover. It did knock it down but you can still feel the spots and there is a ring that is etched into the paint. Usually the sap spots in our area are small spots that come off easy. I have never come across sap so thick and heavy.
    I am a hobby detailer, I have 2 years experience with a DA and almost 40 with a rotary. I use to do paint and bodywork.
    Any tips or suggestions would be great.
    Thanks
    Re: Sap removal.
    Glass Cleaner is a good one sometimes...
      Re: Sap removal.
      Hi.
      Try to use alcohol, solvent or acetone.
      I use 100% alcohol with cotton disc.
        Re: Sap removal.
        Evgeny, I tried the alcohol and it worked great. Thank you for the tip.
          Re: Sap removal.
          You are welсome.
            Re: Sap removal.
            also mineral spirits can work on the quite well along with tar
              Re: Sap removal.
              Yes this work and I always be sure to clean the product off the vehicle well either with lots of water or detailing spray. I do not like to leave on the vehicle for fear of damaging paint
                Re: Sap removal.
                The Goo Gone Automotive Specific Formula has worked well for me in the past. Always a good idea to neutralize surface with a pH balanced car wash soap after application. From there, assess any stain & address as needed, can always do some light sanding (3000 Grit Foam Backed Disc like Meguiar's Unigrit or 3M Trizact) if needed to assist in removing a deep etching.
