Last Touch D155 vs Quick Detailer
  • Last Touch D155 vs Quick Detailer
    Hi all
    I've decided to buy some D155 in bulk as I go through a bit of this stuff.
    I understand that as a QD you use it straight of the bottle but as clay lube you dilute 1:1 (50% product/50% water).
    I've been using the red botte QD up till now as both clay lube and a QD.
    I was just wondering, if the red QD can be used as a QD or clay lube out of the bottle - why do the ratios change with 155?
    I get that you dilute to increase lubricity(or maybe I have that the wrong way around), but why is the red QD lubricated enough to be used as a clay lube but also thick enough to be used as a QD but D155 requires changing?
