Meguiar's Hybrid Paint Coating - Page 6
Page 6 of 9 FirstFirst 123456789 LastLast
Results 51 to 60 of 89
Thread: Meguiar's Hybrid Paint Coating
  1. #51
    9,197
    104
    Re: Meguiar's Hybrid Paint Coating
    Hi jas84,
    Yes, after 1 year or so, and you want to re-apply, you can do as you mentioned, reapply after washing & prep (compound/polish). If you would like to switch back to traditional waxes & it is has only been 3 - 6 months etc. with hybrid paint coating on, you may need to use a something stronger like a compound to remove the coating.
    Yes, our Hybrid Ceramic Product Line is great for maintenance & recommended
    The temperature should be the minimum recommended for application (60F) for a couple of hours while spraying & wiping as you mentione. Also, you need to be careful with heat. Make sure to read the full label including the product precautions on the back of the Hybrid Paint Coating packaging box. This product should only be used with adequate ventilation.
    As far as messing up, not much you can do to mess up appearance.
    Quote Originally Posted by Intrepid00 View Post
    That's one thing that seem vague to me. I live in Florida and while I can park in shade or garage to apply If it is 98 degrees out it is still going to be 98 degree body panels. What is the ideal temp range we should be applying in? I applied my coating on a 66F day and left it garage parked for over 36 hours. No water exposure for 7 days. The actual coating was so easy to apply compared to the washing and polishing I'm actually still nervous I did it wrong but I can really tell it's there after a very long car trip and the car looking clean till the end and I hit a cloud of mosquitos (which were really easy to remove with just some foam with gold class car wash and a power washer. Didn't even need to physically touch the car to wash it. Just used detailer on a 3 problem spots)
    Does humidity play any part? Big part of Florida and we can have 90%+ humidity.
    What is the 1 year+ time calculated on? UV radiation can be intense in Florida and it can really, really, rain here and a lot (Love bug season is going to really put the product to the test too). I'm not expecting a 1 year plus with this and I will be shocked if I get a year with the product. If I get a year you made an amazing product.
    I'm using the blue ceramic spray to maintain the coating but I use that to keep up the coating how will I know when the coat is gone because the beading isn't going to stop.
    Intrepid00,
    The member stated he was considering using a space heater in his garage. I stated be careful with heat; I was referring to his comment on the use of space heaters, subsequently advising member to read the entire product labels, which has more information around proper use. I will edit my response to be more specific.
    From what you described your application sounds proper. Preparation, like the use of clay, compound/polish if needed, followed by the included M122 Surface Prep Spray, & two coats of Hybrid Paint Coating an hour apart from each other, with the application itself applied above 60F, not exposing to water for 12-24 hours & ideally 7 days for the full cure.
    Regarding applying on a hot day, as long as the panels are not in direct sunlight & you are working in the shade, we do not anticipate any issue, except for maybe a little harder wipe off.
    No special recommendations around humidity for this product.
    As mentioned on the label, our up to 1+ year paint protection is based on water contact angle lab testing & predictive modeling. It's difficult to get into more specifics without potentially sharing too much, but essentially driving around, washing weekly, and testing certain characteristics, repeat. It has also shown to perform very well in a variety of environments. Regarding UV, in our testing it performs great. A couple of the top variables which can really affect the long term durability of a coating is where the vehicle is being parked & how often it is washed. Try to avoid parking in a spot where it may potentially get constantly abused, for example, next to sprinklers or under trees if it is going to rain. Regarding washing, try to wash weekly. The longer environmental contaminants sit on top the paint surface, the more likely they are going to affect your paint protection, with any product that is being used.
    Even if maintaining with our Hybrid Ceramic Detailer, Hybrid Ceramic Spray Wax, or Hybrid Ceramic Wash & Wax, we recommend re-applying Hybrid Paint Coating around once a year for optimum performance. With that said, it can last longer if the vehicle is really kept up well, and additionally, extreme weather or situations, like salt from roads, harsh chemicals, or lack of washing, it may not last as long as well.
    800-854-8073 ext 3845
  2. #52
    9,197
    104
    Quote Originally Posted by jcmgt View Post
    - Can this be stored in areas that will see below 32F?
    - once cured, can a topper (m26) be applied without damaging the film?
    Quote Originally Posted by Evgeny View Post
    Good question above. I am planing to buy, but worried about transportation in low temperatures or near 32F.
    Hi there,
    As with all of Meguiar's Products, prolonged exposure to extreme heat or cold or freezing is not recommended & the products should be stored at room temperature. We would not be concerned with cold temperatures if you are buying from an auto parts store, driving home, & bringing into room temperature or receiving a delivery from an on-line supplier. We also have agreements with the carrier companies which pickup from our warehouse that the products do not get exposed to extreme heat, cold or freezing. Again it is just prolonged exposure to extreme heat or cold or freezing, is not recommended.
    By the way, at the time of this post, Advance Auto Parts, AutoZone, O'Reilly Auto Parts, and Pep Boys show to carry Hybrid Paint Coating, as well as many on-line suppliers.
  3. #53
    Feb 2021
    FL
    3
    How much does a car wash harm it (hand or personal electric power washer not tunnel)? We have love bug season coming and I have no choice but to wash the front of the car constantly for a month.
    I'm just worried I'll try to apply it too soon. I saw in an earlier post that said if you wait too long before 2nd coat you might not get it to bond right. I'm guessing if I clay it if needed (after a year I'm sure it will need it but new car here so I didn't need to first time) and polish it (I did do this with ultimate polish) that after a year I won't have to worry about bonding issues?
    All and all I'm so far very happy with this. It's really protected the polish and letting the car keep a deep reflection.
  4. #54
    9,197
    104
    This product is very resilient to traditional hand washing, so you made a good choice. Feel free to wash it as much as you have to, and ideally at minimum every week, if daily driven. Also, it sounds like you plan to, but you should work to remove the love bugs as soon as you can, as they can begin to etch into the paint or in this case your paint protection. Hybrid Paint Coating should make them easier to remove.
    When applying Hybrid Paint Coating, it is recommended to apply two coats 1 hour apart, to ensure even coverage.
    When it comes to preparing the paint for re-application after around 1 year has passed, the vehicle will more than likely need to be treated with a clay bar, like our Smooth Surface Clay Kit, so you process would be, Wash, Clay, Compound/Polish if desired, then re-apply Hybrid Paint Coating. Our Iron Removing Spray Clay is also a great additional but optional choice for further decontaminating the paint prior to application.
  5. #55
    Apr 2011
    USA
    3
    Is a topper, such as m26 friend or foe?
  6. #56
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    5,676
    67
    M26 is not needed. You will mask all of the attributes of the hybrid paint coating.
  7. #57
    Apr 2011
    USA
    3
    I understand it's not needed from the protection perspective. I ask as in the past I've used a topper to clear water spots or give the extra pop before a show.
  8. #58
    41
    19,279
    240
    I think you would just be wanting one of the quick detailer type products for that.
  9. #59
    Jul 2013
    Lawndale, CA
    5,676
    67
    Stick with a ceramic type product for a topper.
  10. #60
    Jan 2021
    San Francisco, CA
    Thumbs up Re: Meguiar's Hybrid Paint Coating
    [QUOTE=rover137;597066]Hey Nick
    i know you mentioned that the Ceramic Detailer/Bead Booster range can be used to maintain the Hybrid Costing but hoping to get a little bit of the science around this. The coating itself doesn
  1. Meguiar's Hybrid Ceramic Spray Wax
    By Nick Winn in forum Meguiar's 2019 New Products
    Last Post: Nov 24th, 2021, 07:06 AM
  2. How to use Meguiar's NEW Hybrid Ceramic Wax!
    Last Post: Oct 22nd, 2021, 10:48 AM
  3. Meguiar's M788 Deep Crystal Ceramic Paint Coating Kit
    By Nick Winn in forum Meguiar's 2020 New Products Introduction Thread
    Last Post: Jan 26th, 2021, 06:10 PM
  4. Why Hasn't Meguiar's Introduced a Paint Coating Product Yet?
    By Wyle E Coyote in forum Detailing 101
    Last Post: Oct 21st, 2017, 01:06 AM
  5. Meguiar's M16 and M188 Deep Crystal Paint Coating [NEW]!
    By tapp1 in forum For Sale or Trade
    Last Post: Nov 20th, 2015, 11:30 AM
