ULW over Cleaner Wax?
Results 1 to 9 of 9
Thread: ULW over Cleaner Wax?
    Oct 2015
    St. Louis, Missouri
    7
    6
    I have a 2016 minivan that I bought last year. Did clay bar and applied Ultimate Compound last year to address swirl marks visible in the sunlight. They still seem to be present. I'm concerned about repeating the process as I tend to hang on to my vehicles and I don't want to cut too deep into the clear coat. I understand Ultimate Compound is likely more abrasive than the Cleaner wax, so I may just live with the swirl marks. Thinking of applying Cleaner Wax then ULW, mostly because I already have them on hand. Waste of time? Should I just go with one or the other?
    Thanks.
    Dec 2015
    San Juan Capistrano CA
    753
    Re: ULW over Cleaner Wax?
    Which do you feel is more likely for your processes?
    1) Did your use of UC not fully remove many of the small scratches last year?
    2) Did your washing/cleaning processes used in this last year add new scratches (examples, brushes, drive through car wash, dirt caught in towels)?
    Dec 2015
    753
    You should be OK to put Ultimate Liquid Wax over Cleaner Wax.
    If you like Meguiar's Cleaner Wax, take a look at Meguiar's new 3 In 1 Wax.
    For under $20, it might get you better results, while also offering a little more protection until you over lay it with Ultimate Liquid Wax.
    Here is the Product Introduction Thread.
    Meguiar's 3 in 1 Wax (meguiarsonline.com)
    Oct 2015
    St. Louis, Missouri
    7
    6
    Thanks for your reply. It doesn't seem UC removed much of the swirls. Maybe some. The vehicle is in good condition but I suspect it had its fair share of automatic washes by its previous owner, whereas I prefer handwashing and I am diligent about keeping my towels and mitt clean.
    Oct 2015
    St. Louis, Missouri
    7
    6
    Thanks for the info. It's tempting but I'll have to go through two bottles of the "old" CW before I move on to the 3-in-1.
    Jan 2007
    Rochester Hills, Michigan
    666
    21
    Did you apply the Ultimate Compound by hand or machine polisher?
    Oct 2015
    St. Louis, Missouri
    7
    6
    Quote Originally Posted by drumdan View Post
    By hand.
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    5,641
    66
    Quote Originally Posted by Neo Fender View Post
    By hand.
    You have reached the limitation of what can be done by hand. You would have to venture into machine polishing to get better results.
    Registered Member james0509's Avatar
    Aug 2009
    Vancouver
    219
    89
    To add on to the comments, you can adjust the cut by the method or the pad. In this case you've reached the pressure you can by hand via pad, you can either use a more aggressive pad or step up to a DA polisher.
    Another alternative is to fill and hide the swirls via glazes if you are more cautious about clearcoat. Meguiars Show Car Glaze, or if you want to spend more $$ Carpro Essence is what I would try (or Chemical Guys Glossworkz.) Carpro Essence is advertised to add more clearcoat thickness since it has semi-permanent resins in it.
    Good luck!
  1. OTC wheel cleaner, bug remover and tire cleaner?
    By TheMidnightNarwhal in forum Detailing 101
    Last Post: Sep 9th, 2018, 02:27 PM
  2. Using Leather cleaner vs Vinyl cleaner
    By JeannieAmato in forum Detailing 101
    Last Post: Aug 23rd, 2016, 02:49 PM
  3. Marine M50 Cleaner/Wax vs Flagship Premium Cleaner/Wax
    By Vettefan in forum Meguiar's Marine/RV Product Line
    Last Post: Nov 28th, 2012, 08:23 AM
  4. Which vinyl cleaner and which interior cleaner
    By Smooth2o in forum Meguiar's Retail/Consumer Line Products
    Last Post: Apr 1st, 2008, 02:10 PM
  5. Wheel Cleaner vs. Tire Cleaner
    By RWayne in forum Detailing 101
    Last Post: Jun 3rd, 2006, 05:16 PM
