Pre Season Boat Detail
Results 1 to 5 of 5
Thread: Pre Season Boat Detail
    May 2021
    Amherst Ohio
    I am getting ready to clean/wax my 33' white fiberglass boat before I launch for summer. The gel coat is in very good shape and I would prefer not to use anything too aggressive on it. Based on many hours of research I am considering using the M50 Cleaner wax to give it a good over all cleaning and bring out the shine even more and then follow up withe Flagship Premium Wax to protect it as long as possible.
    I plan on using my PC DA polisher with the new Lake Country SDO pads. Not sure if I'll use the blue or orange with the M50 Cleaner Wax but I'll use the black pad for wax/sealant.
    Has anyone used a similar process or can offer ideas or suggestions?
    Geowh
    Aug 2014
    anaheim hills, ca
    100
    8
    Re: Pre Season Boat Detail
    sounds good. You can use a more aggressive pad or lesser aggressive pad with the cleaner wax depending on how the boat is responding... so do a test section to see how it responds. Just make sure to clean out your pad with a brush or compressed air every few passes. Gel Coat sheds a lot. I use like 3 pads on my 24 ft boat for just the correction phase and used compressed air to clear out the pad after every (2) 2x2 or 3x3 passes.
    May 2021
    Amherst Ohio
    [QUOTE=twisty roads;597456]sounds good. You can use a more aggressive pad or lesser aggressive pad with the cleaner wax depending on how the boat is responding... so do a test section to see how it responds. Just make sure to clean out your pad with a brush or compressed air every few passes. Gel Coat sheds a lot. I use like 3 pads on my 24 ft boat for just the correctionphase and used compressed air to clear out the pad after every (2) 2x2 or 3x3 passes.[/QUOT
    Thanks for the reply
    What pads/process do you use?
    Aug 2014
    anaheim hills, ca
    100
    8
    Depends completely on the boat/rv/car. I used a MF cutting pad with a lighter compound which finished well so went to straight to a polishing foam pad with wax afterwards.
    Feb 2020
    Florida
    27
    How did the detailing go?
  1. Detail season begins
    By JG_Detailing in forum Show Off Your Latest Detail Work
    Last Post: Mar 7th, 2016, 07:22 PM
  2. Mid-Season Boat Detailing
    By mirrorfinishman in forum Meguiar's Marine/RV Product Line
    Last Post: Aug 9th, 2006, 06:13 PM
  3. Mosca's mid-season detail class results!
    By Mosca in forum Show Off Your Latest Detail Work
    Last Post: Aug 7th, 2006, 08:41 AM
  4. First Detail of the Season
    By mike_svt in forum Show Off Your Latest Detail Work
    Last Post: Jun 7th, 2006, 03:33 AM
  5. First detail of the season 67 Vette convert
    By onawrxhigh in forum Show Off Your Latest Detail Work
    Last Post: Apr 2nd, 2006, 02:15 PM
