M110 & m210
Results 1 to 10 of 10
Thread: M110 & m210
  1. #1
    Join Date
    Jan 2007
    Location
    Rochester Hills, Michigan
    Posts
    681
    Rep Power
    21
    M110 & m210
    Good gravy, guys.
    Bravo!
    In all honesty, I started reaching for another line the past couple years. Still use it, and enjoy it.
    However...
    I've had these two on the shelf for a while now, and played with them, but hadn't put it to the test until today, and that was removing sanding marks on a texture match job.
    I experimented M110 with Buff and Shine Uro-Fiber, and the original Rupes blue microfiber pads. The machines were a Rupes Duetto and Mini. In the end Uro-Fiber is what I ended up using to complete the cutting.
    That M110 has a serious cut to finish ratio. It destroyed Menzerna FG400, Jescar Correction Compound, Koch Chemie H9, and Rupes DA Coarse. It out cut them and out finished them. I didn't even need the M210, but I gave it a go, and it was actually too nice for what the job paid. The M110 cut approached 3D ACA500, and AAT501, but finished cleaner.
    The M210 was used with Buff and Shine yellow Uro-Tec polishing/finishing pads, similar to Rupes Yellow.
    What is nice about these polishes is that I can almost tell they were designed with the da in mind. I'm sort of surprised there hasn't been more of a buzz about them. I imagine there are some like me that got hooked on the 3D stuff, and / or they're quietly using M110 and M210 quietly in their operations.
    There are a lot of new brands and products on the market, but these two might just become a staple in people's arsenals. I'm still sort of reeling from shock at how nice they were to use, and the results they produced. Seriously stunned.
  2. #2
    Product & Training Specialist Nick Winn's Avatar
    Join Date
    Sep 2010
    Location
    Irvine, CA
    Posts
    9,105
    Rep Power
    104
    Re: M110 & m210
    Thanks for sharing drumdan! I experienced the same sort of shock & fun you did when I used this pair for the first time on a whole car, on 06 Black Lexus, years & years of heavy swirls, scratches, rotary swirls, was running a 21mm D/A with our DMC6 D/A Microfiber Finishing, blowing through just about everything in one attempt, going to wipe the residue off with zero ticks, zero micro marring, & literally almost perfect paint on a soft-ish/sensitive black lexus, so fun & impressive. Thanks again for sharing.
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
    800-854-8073 ext 3845
  3. #3
    Join Date
    Jan 2007
    Location
    Posts
    681
    Rep Power
    21
    Re: M110 & m210
    Quote Originally Posted by Nick Winn View Post
    I love it, Nick! Thanks for sharing too!
    One of the first cars where I played with it was the good of a black 1995 Porsche 911. It was in horrendous condition. I was at work that day, a shop called Fade To Black in Clawson, MI. I was using a PC 7424, the Uro-Fiber, and M110. It looked so good that one of our customers that brings in Lambos, Bentleys, McLarens, etc took a picture to show their porters. I didn't show him the M110 though. He saw the Menz 400 that I used on the rest of the car - which was provided by my employer.
    Seriously, these twins need more attention than they get from the influencers.
  4. #4
    Join Date
    Jan 2007
    Location
    Posts
    681
    Rep Power
    21
    Re: M110 & m210
  5. #5
    Registered Member
    Join Date
    Jul 2018
    Location
    Denmark
    Posts
    26
    Rep Power
    4
    Re: M110 & m210
    Have you had any issues with dust from the M110?
  6. #6
    Michael The Guz's Avatar
    Join Date
    Jul 2013
    Location
    Lawndale, CA
    Posts
    5,660
    Rep Power
    67
    Re: M110 & m210
    Quote Originally Posted by Vifa View Post
    It does produce a little bit of dusting. Nothing like M100. M101 or M105. More like D300.
  7. #7
    Registered Member HCAD's Avatar
    Join Date
    May 2009
    Location
    Lynchburg, VA
    Posts
    534
    Rep Power
    18
    Re: M110 & m210
    They are my main characters in paint surface correction, by far. Occasionally I'll use D300 on a soft clear coat.
  8. #8
    Join Date
    Jan 2007
    Location
    Posts
    681
    Rep Power
    21
    Re: M110 & m210
    None as of now. Probably similar to D300, which is very little.
    It does brush out of the pad well, where and when you'd want it to dust.
  9. #9
    Join Date
    Jan 2007
    Location
    Posts
    681
    Rep Power
    21
    Re: M110 & m210
    Reporting further:
    Last week we had a Bentley SUV come in for a paint correction and coating. Black. I started out with 3D ONE, and it did a good job on the hood. Uro-Fiber and Adam's Swirl Killer 15.
    The trouble came when I got to the front fender. Super deep lacerations, and damage from automatic car wash brushes. Friday was my day off, so after I was done with my customer, I went to the shop armed with a variety of compounds. Among them were Rupes DA Coarse, 3D ACA500, 3D AAT501, Koch H9, Menzerna 400, Jescar Correction Compound. M110 was the one that removed the most damage by a noticeable margin. ACA500 was the closest to M110. Most sections M110 cleared out 95+% of the defects. I also tried D300, and it did a respectable job, but didn't reach the levels of correction M110 provided.
    I'm really excited to learn this, because It's such an enjoyable product to use. The findings that it also performs like a champ is turning this into my holy grail compound.
    I'm going to keep testing M110, and am anticipating that it will become my go-to compound.
  10. #10
    Join Date
    Jan 2007
    Location
    Posts
    681
    Rep Power
    21
    Re: M110 & m210
    Quote Originally Posted by HCAD View Post
    That makes sense.
    I have M205 sort of positioned as a possible one step solution as I have for years. It often does a great job at light to moderate correction and leaves a glossy finish. I have had finishing issues with it on very rare occasions. I still have to try M210 in that capacity as well.
    D300 is the house compound at the shop. We use it by the gallon.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Which foam pad for M210/M205
    By White_Turbo in forum Detailing 101
    Last Post: Feb 26th, 2020, 04:24 PM
  2. Meguiar's Professional M110 Ultra Pro Speed Compound
    By Nick Winn in forum Meguiar's 2019 New Products
    Last Post: Oct 23rd, 2019, 11:19 PM
  3. Larry Kosilla puts M110/M210 to the test
    By Michael Stoops in forum Meguiar's Professional Lines - Mirror Glaze, Detailer, PRO Hybrid Ceramic & Other
    Last Post: May 3rd, 2019, 05:58 AM
  4. Meguiar's Professional M210 Ultra Pro Finishing Polish
    Last Post: Apr 29th, 2019, 08:52 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
