Just painted polish without sanding ?
Results 1 to 10 of 11
Thread: Just painted polish without sanding ?
    Aug 2020
    Qu
    6
    Not sure why but the forum keep cutting my post ,
    i reposted the question in the 3rd post
    thanks
    Quote Originally Posted by Pjackb View Post
    Hi
    I just got one of my car painted, the prep work was flawless and the paint was laid down really well and has very minimal orange peel. This is not a show car and I do not need a full mirror shine therefore I do not intend to get a full wet sand and polish done on it (especially since they charge about $2K for a quality job in my area.)
    My real question however is if a polish is worth it and will it make the paint “pop” the car is completely stripped of everything so it’s the right time to do it.
    this is the list of products I have on hand M105, M205, M305, Ult Compound, Ult Polish, M26 and AG SRP.
    I have a nice rotary and a budget DA from Eastwood but because I am inexperienced I would prefer to use the DA on the new paint.
    I was thinking to do the 105, 205,305 combo since it says they are safe for new paint but again the big question is will it be worth all the work without sanding ?
    Dec 2015
    San Juan Capistrano CA
    767
    Re: Just painted , polish without sanding ?
    It looks like the font your device is using is sending an "End of File" character for the apostrophe.
    Try entering your message again and skip the apostrophe. Example use " I am".
    Aug 2020
    Qu
    6
    Hi
    Aug 2020
    Qu
    6
    Thanks Not sure why it’s doing this I reposted the question
    Dec 2015
    767
    Re: Just painted polish without sanding ?
    First. I would contact the painter and ask how long the paint should be left to cure or off gas before working on it.
    It is normally best to use test spots, working from least aggressive to more aggressive until you get the results you desire.
    This means not starting with M105. Instead start with UP or M305. If that results are not good enough, then move to M205 or M210. Then only if the results are not met, try the M105 or UC.
    Dec 2015
    767
    "Will it be worth all the work without sanding?"
    That depends on the quality of the paint preparation and paint job, plus how the paint reacts to the processes.
    Aug 2020
    Qu
    6
    Thanks He told me 48hrs and the following are the recommendation by Dupont for the clear coat used
    I'm not sure which is a finishing compound or polish
    Aug 2020
    Qu
    6
    Thanks He told me wait 48hrs and I wont get to it before at least a couple weeks .
    the following are the recommendation by Dupont for the clear coat used I'm not sure which of what I have is a finishing compound or polish or if I need to get something else
    Dec 2015
    767
    Here is a video where Mike Stoops speaks of the benefits of doing test spots.
    Dec 2015
    767
    I like this video from Mike Stoops on Test Spots.
    This truly is one of Mike Stoops best educational videos. Congratulations Mike.
  1. Minor Swirl Marks after Sanding/Compound/Polish/Wax
    By locorecto in forum Detailing 101
    Last Post: Aug 23rd, 2018, 08:34 AM
  2. Polish-Buffing-Cleaning-Compound-Sanding Index Chart (Rough Estimate)
    By RedPanda in forum Meguiar's Professional Lines - Mirror Glaze, Detailer, PRO Hybrid Ceramic & Other
    Last Post: Dec 3rd, 2016, 01:41 AM
  3. Wet-sanding - Fresh Paint vs Factory Paint
    By Mike Phillips in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Sep 15th, 2011, 06:39 AM
  4. Wet Sanding Scratches and Applying Ulti. Compound and Polish
    By Broseph in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Sep 3rd, 2011, 08:40 AM
  5. Can You Use the PC to Polish-out #2000 Grit Sanding Marks?
    By JJ1 in forum Hot Topics & Frequently Asked Questions
    Last Post: Apr 15th, 2007, 10:02 PM
