Paint correction on a older car.
Results 1 to 10 of 12
Thread: Paint correction on a older car.
    Sep 2021
    Detroit
    4
    Hello,
    I am new to paint correction. I bought a 1978 Trans Am SE with original paint I would like to restore. The car has scratches and swirls. I used Meguiar's Ultimate compound and a orange Chemical Guys buffing pad. The car looks good in the garage, but when the sun hits it I can still see swirls and scratches. I'm guessing I need something more aggressive. What are some suggestions to do next? I have a Black and Decker dual action buffer. And what speed should I use? Thanks in advance for your advise.
    David
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    5,668
    67
    Re: Paint correction on a older car.
    The buffer you have will not do the job. It is referred to as a wax spreader. You would have to get a dual action polisher to remove defects.
    You could look into Mike Phillips and #7 show car glaze wipdown. Just google it. It won't remove scratches but bring back luster to the paint.
    Sep 2021
    Detroit
    4
    Sorry, I have the dual action polisher. Thanks for the advice i'll look it up.
    9,112
    104
    Feel free to let us know if you have further questions or provide an update on how the project is going.
    800-854-8073 ext 3845
    Sep 2021
    Detroit
    4
    I got some advise to use Chemicals Guys yellow pad, Ultimate Compound, and put the polisher on 3. Another person told me to wet sand it, polish, and wax it. I got a quote for $1500 for paint correction and ceramic coat. The video Mike Phillips #7 show car glaze doesn't sound like it corrects the scratches and webbing. After watching the full video they also said if you have a hard shine that #7 won't do anything. My car looks great in the garage, but once the sun or a flashlight hits the paint to can see webbing and defects. So I am still up in the air on what to do. It's original paint. It has flaws from the factory so I know it will never be "show car", but I would like it the best I can. I don't want to waste my time "trying" different stuff. And I have no problem putting the work in. If you can give me advise I will take it. The more I research on the internet the more I get confused of what I should do. I can take pictures or a video if needed. Thanks in advance.
    Dec 2015
    San Juan Capistrano CA
    792
    Look hard at the webbing. This can come from the lower level of the paint as well as the top.
    If it is "lacquer checking" from the lower levels that can not be wet sanded and then polished. You would end up wet sanding to the point of the paint being too thin.
    Here is a link on lacquer checking" or other similar type paints.
    Lacquer paint checking question (meguiarsonline.com)
    I would suggest trying the Mike Phillips method. It is not a cure, yet you may find it gives the best results (until a repaint).
    Sep 2021
    Detroit
    4
    The swirls and scratches are from the car wash. I haven't ruled that out using #7 yet. The car looks great in the garage, but once the sun hits it I can see swirls and fine scratches. I'm going to try and heavier pad, lower speed, and then #7. Or should I try #7 first?
    Dec 2015
    792
    Jun 2010
    750
    21
    By all means read and re-read the article. I've used the process numerous times, including my old El Camino, which I turned from faded pinkish burgundy paint to a cover car on the National El Camino Owner Association calendar. The M07 by itself has no abrasives, but when it's aggressively rubbed into old lacquer paints, it will remove oxidation, polish the exposed metallic particles in the paint and most importantly moisturize the aged paint to make any subsequent polishing more effective.
    A small bottle of M07 is about $15. Try a test spot, using Mike's process, then decide if you want to do any further paint correction.
    Bill
    Sep 2008
    Indiana
    56
    14
    Are we sure it's a Lacquer paint? Are you sure it's single stage? Odds are it's basecoat / clearcoat and can be dealt with like any other 2 stage.
    Take a towel with your Ultimate Compound on it and rub the paint a bit, if the towel picks up color it's single stage. If not, it's basecoat / clearcoat.
    Either way you need to get more aggressive if you want to completely correct the paint. The first thing I would recommend is getting a Porter Cable, Griots, or other high quality DA that will have the power to correct. Second, start looking at more aggressive pads like microfiber, there are a couple different cutting levels of those.
    The Ultimate compound is good stuff, I use the M105 which is the same thing. Question though.....what did you use AFTER the Ultimate Compound? You may be seeing micro marring from the UC and orange pad?
    You need to work your way down in aggressiveness, usually Ultimate Polish does a great job as a second step though sometimes it will take couple passes. Take your time, it's cool that the car has original paint and it adds to the value.
  1. Looking for help with m105 compound on older paint
    By GT-LIFE in forum Detailing 101
    Last Post: Aug 1st, 2018, 11:36 AM
  2. New member looking for help with m105 compound on older paint
    By GT-LIFE in forum Introduce Yourself - New Members
    Last Post: Jul 27th, 2018, 09:42 AM
  3. older paint prep for winter
    By gr8dryv in forum Introduce Yourself - New Members
    Last Post: Dec 4th, 2015, 09:02 AM
  4. Dealing with older single stage paint
    By margallar in forum Detailing 101
    Last Post: Oct 9th, 2012, 11:41 PM
  5. Older Single Stage Paint
    By BillE in forum Working by Hand
    Last Post: Jan 31st, 2012, 04:59 AM
