Meguiar's Hybrid Ceramic Paint Prep
Results 1 to 10 of 14
Thread: Meguiar's Hybrid Ceramic Paint Prep
    9,166
    104
    Meguiar's 2022 New Product - Announced November 2nd, 2021
    Revive Paint & maximize Hybrid Ceramic wax performance!
    • One step paint correction removes very light swirls and other minor defects, leaving the paint glossy!
    • Uniquely formulated to prepare the paint for Meguiar's Hybrid Ceramic protection
    • Removes very light defects without hazing like a traditional compound
    • Leaves deep glossy reflections like a polish
    • Creates an SiO2 base to increase Hybrid Ceramic Wax bonding
    • Engineered with hand application in mind - easy on easy off!
    Part Number: G220416
    Contents: 16 fl oz
    US MSRP: $12.99
    800-854-8073 ext 3845
    Mr. greg0303's Avatar
    Nov 2009
    Brooklyn New York
    2,903
    69
    Re: Meguiar's Hybrid Ceramic Paint Prep
    Specifically designed to prep paint for Hybrid Ceramic protection.
    I'm glad Meguiar's came out with this specific product. On my list to get.
    Nov 2009
    Brooklyn New York
    2,903
    69
    Can Hybrid Ceramic Paint Prep be applied by D/A polisher or hand application will deliver the best results ?
    9,166
    104
    Quote Originally Posted by greg0303 View Post
    Yes, it can be applied by D/A Polisher / Random Orbital, that said Hybrid Ceramic Pre Wax Prep is more tuned for hand application.
    Jun 2014
    Ottawa, Ontario
    19
    8
    So if you finished the paint down glossy, with say #7 show car glaze, would you still use this over it before a coating like M27 or just go straight to the coating as the paint is glossy already? Or does the prep create a better bond for the si02 so go ahead with this new si02 prep?
    Jun 2014
    Ottawa, Ontario
    19
    8
    This also takes the step out of a dedicated IPA (m122) style product, as it preps surface for an si02 coating??
    9,166
    104
    Quote Originally Posted by Buddy View Post
    If you have already removed defects to your satisfaction and/or polished, there would not be a huge need or benefit to use this. This would be used in a situation where a paint/cleaner / swirl remover product or polish has not been used, and your wanting to provide defect removal, added gloss, and the added benefit of a base layer of Hybrid Ceramic/Sio2 - this product will remove defects, polish the paint + it happens to lay down a nice base layer of Hybrid Ceramic protection.
    This would not be ideal to use prior to a paint coating, since it leaves behind protection which you would then have to strip off & even our M122 Surface Prep Spray included in our Hybrid Paint Coating Kit is not designed to strip waxes or sealants - it is more for removing remaining oils & residues - this does not mean it can't remove waxes or sealants it is just not designed to.
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    5,676
    67
    Nick, so this would not work in conjunction with the hybrid paint coating or M27?
    Jul 2008
    Crest Hill, IL
    162
    15
    Can m27 be used over this? I’m assuming the hybrid liquid wax can. Either way, is there a cure time between this and those?
    Sep 2021
    Cottingham, East Yorkshire, UK
    9
    As a "paint prep" how long after application should a top coat be applied, will spray on hybrid ceramics work straight from the spray on stage, or should you go with hybrid liquid ceramic on top? Then maybe go to spray on hybrid as a weekly or monthly top up? Also if you have defects that require more cutting than the new product would you go ahead and use the ceramic paint prep as a finisher? Then layer on top? I suppose I'm wandering if paint prep is an LSP to be built upon in subsequent washes or should another sealant be added after cutting with paint prep? Thanks for your time.Phil. Kia Kaha.
  1. Replies: 10
    Last Post: Dec 1st, 2021, 05:42 PM
  2. Meguiar's Hybrid Ceramic Spray Wax
    By Nick Winn in forum Meguiar's 2019 New Products
    Last Post: Nov 24th, 2021, 07:06 AM
  3. How to use Meguiar's NEW Hybrid Ceramic Wax!
    Last Post: Oct 22nd, 2021, 10:48 AM
  4. Replies: 2
    Last Post: Mar 22nd, 2021, 10:07 AM
  5. Meguiar's Hybrid Ceramic Detailer
    By Nick Winn in forum Meguiar's 2020 New Products Introduction Thread
    Last Post: May 4th, 2020, 09:43 PM
