Bugs Bugs and more Bugs
Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: Bugs Bugs and more Bugs
    Nov 2004
    46
    17
    I need to know what everyone uses to break up the dried on bugs. I have tried several things nevthing ever seems to break up the bugs and I end up with a sore arm.
    Anything that helps.
    LMK
    2008 Jet Black BMW X3
    2007 Ford Fusion 5 Speed
    Registered Member rusty bumper's Avatar
    North Carolina
    3,687
    88
    Re: Bugs Bugs and more Bugs
    LMK
    Have you tried soaking the bugs when you wash your car?
    They tend to come off easier after the water & soap has had a chance to penetrate them.
    r. b.
    60
    24,759
    520
    One of the people that attended a detailing class a while back recommended placing a wet wash rag on a dried bug and letting it soak for a while, if your car's body style lends itself to this kind of thing you could take this though one step further and saturate a bath towel and place it on the front of your car and then while washing the rest of the car periodically re-wet the towel to enable water to continually be in contact with the dried bugs. After you finish washing all of the rest of the car, remove the wet towel and wash the front of the car, hopefully by then the bug splatter will have softened enough to enable you to wash and loosen them from the finish.
    North Carolina
    3,687
    88
    Sounds like a great idea.
    I've seen the time when I wanted to remove a few tough bugs from the windshield without getting the car wet in the process.
    Looks like a person could soak a sponge and place it over the bug/glass without wetting the car.
    r. b.
    Nov 2004
    46
    17
    Re: Re: Bugs Bugs and more Bugs
    how do you soak them when they are on a vertical surface?
    North Carolina
    3,687
    88
    Re: Re: Re: Bugs Bugs and more Bugs
    Read Mike's suggestion above and see if that might be feasible.
    r. b.
    Mar 2005
    243
    19
    A little QD on a MF towel then hold it there for a few seconds. they come right off. That's the process I use when I'm walking back to the car and notice a bug splatter, but the car is not in need of a wash. I suppose water can be used in this scenario as well. The QD is probably only saturating the bug at this point, so water will probably do the same. If you are in process of washing, soapy water couldn't hurt
    Jun 2005
    151
    18
    I too have a problem with bugs this time of year.
    I recommend the following:
    1. a good coat of wax (makes removal easier)
    2. a good instant detailer, like Quik Detailer
    I remove the bugs atleast every two days with the detailer and a 100% deep pile terry towel. A microfiber just doesn't have enough bite to remove bugs, imo. Spray the QD and let in penetrate for a minute. Then spray the QD again and remove. Then repeat process if necessary. Then buff with a clean towel. This proactive approach will keep your vehicle looking good and make washing a lot easier. It only takes a few minutes to use this process.
    Some insects if not removed fairly quickly will bond with the paint and etch your surface. It is easier to spend 10 minutes a couple of times a week rather than later having to repaint your vehicle or having to bring out the power equipment to try to fix the surface defects.
    Bama
    Wheel & Tire Moderator evo77's Avatar
    Aug 2004
    44
    149
    19
    These tips might work well on a recently waxed surface but what about a neglected one?
    Bug splatters will stick much harder to a wax-less surface and will always be more difficult to remove.
    Is there a product from the Meguiars lineup that can be applied directly to the trouble spots to rub away the bug guts? Maybe a bug and tar remover or something?
    Aug 2004
    44
    149
    19
    Ah-ha, just found these.
  1. Love bugs
    By 3JBS in forum Detailing 101
    Last Post: Sep 18th, 2009, 01:58 PM
  2. Bugs, Bugs, BUGS, and MORE BUGS!!!!!
    By Tillmanator in forum Hot Topics & Frequently Asked Questions
    Last Post: Oct 27th, 2008, 02:41 PM
  3. Got bugs?
    By Nick Chapman in forum Show Off Your Latest Detail Work
    Last Post: Aug 18th, 2008, 07:03 AM
  4. Bugs!!!! I hate Bugs!!!
    By Anvstang'04 in forum Detailing 101
    Last Post: Jul 7th, 2008, 07:47 AM
  5. Help removing bugs
    By JLTSX07 in forum Interior Care
    Last Post: Apr 18th, 2008, 12:45 PM
