Leaf Blower
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Leaf Blower
    Aug 2005
    508
    20
    Leaf Blower
    I was wondering, a lot of people have talked about using leaf blowers for drying a car/truck and j333_76484 said something about the water magnet and other drying towels slightly scratching so j333_76484 uses a leave blower and supposedly it worked better. Anyone have ideas as to wether or not it's a good idea to use one (pros and cons) and what kind of leave blower do you use or recommend buying. (brand, model)
    Registered Member Jeff Smith's Avatar
    Jul 2005
    53
    1,254
    27
    Re: Leaf Blower
    Just to add a little clarification here before some folks misunderstand what I meant. I do use the Water Magnet and the Super Plush Terry as well as multiple other accessories from Meguiar's to wash the truck down. I find all of the stuff to be the best I have found on the market. But, having said that, I think most will agree that from time to time a person will induce their own towel induced marks. I think it is inevitable. Proper techniq will reduce the odds of this but sometimes during the drying process some errant dust may well fall on the vehicle and "ANY" towel would stand the chance of rubbing it on the finish.
    I just wanted to clarify so as not to create any confusion and mislead people into thinking the Water Magnet or the Super Plush Terry Towels themselves were causing the problem. I will still be using these most likely every 3rd wash or so because when using the leaf blower you are standing back a few feet and can't necessarily see some of those little above surface contaminates that you might have missed during the wash. Sometimes these can be removed when a little extra towel pressure or (Forgive Me Here) picking at it with a fingernail.
    Jeff Smith
    Don't mistake my enthusiasm for experience.
    Registered Member BJClarke001's Avatar
    Jul 2005
    251
    17
    Re: Leaf Blower
    Hey F-150,
    First off, let me tell you what I have for a Blower. It is a Craftsman, 210 MPH, 2 HP, 12 Amp (it's electric). I think it was like $70
    Now, I didn't specifically buy this for my car and was used to do, well, er, ummm, leaves. LOL. But I did migtate it into my Car Care routine just this year.
    This is my thought. No matter how soft (and good) a drying towel may be, there is still friction. Ontop of that, if I missed even a single piece of grit during my wash process, I could by chance drag that around in my drying towel and hence, scratch my finish.
    So, I added the blower to my routine. No friction at all tells me I have reduced the chances of those fine scratches.
    At first, I use to totally dry the vehicle with the blower. This can be time consuming because you end up chasing water drops around your finish. Don't get me wrong, it does dry eventually but take a little more time. Because of the time factor, I now use the blower to dry the vehicle , maybe about 90% and follow up the last 10% with the water magnet.
    Pro's:
    1) No friction on your finish.
    2) Less towel usage and thus, needing to wash them in the machine.
    3) It dries wheels and tires great
    4) Works best when on a waxed surface
    Con's:
    1) Another added expense to your car care arsenal. (your gf/wife may just leave you)
    2) You gotta wear ear protction. These things are freaking loud. Especially like me doing it in my garage.
    3) Your neighbors think you just lost it and verifies to them you are now insane.
    4) Depending on where you do your car care, your going to need an extension cord and be near electric. Unless you go to gas power and I am not sure if you wanna go there. I would have to think that one over.
    Well, thats my spin. Good Luck.
    Brad
    Detailing a Vehicle is very Therapeutic.
    Jul 2005
    53
    1,254
    27
    Re: Re: Leaf Blower
    I agree with the 90% concept. Some water just hangs on. You can chase a drop all over the place and it just won't blow off. Eventually it will dry up.
    This is why I started immediatly Speed Detailing after drying. Takes me just a few extra minutes of effort but with using the soft padding in the Quick Detail Pad along with the "lubricity" of the Speed Detailer, anything I might pick up will lubricated by the Speed Detaler and then while still wet wiped off on the Dry side of the pad. Plus I think the fresh Speed detailing really adds to the shine.
    Usually by the time I start SDing the remaining water droplets are extremely small and even if they did dry up they will not have sat there long enough to make a mark. Even if they did the SD will get them. This works for me.
    Jeff Smith
    Des Moines, Iowa
    40
    5,605
    76
    Having just purchased a Shop Vac with a removable blower.... The blower does a real nice job getting the water out of the hidden spots. The list of BJClarke001 pros and cons is accurate IMO.
    Getting a shop vac with the blower is the best way to go if you are not sure the blower option is for you. If you don't like how it dries the vehicle you can still use it as a shop vac.
    Brandon
    2007 Black Chevy Avalanche
    My Albums: Avalanche
    Registered Member Xtreme99_s-Dime's Avatar
    Jul 2004
    134
    17
    I would agree that a leaf blower gets the job done quite well. However, there is still some friction, but not nearly as much as using towels/MF's
    What concerns me is the speed that these blowers are made to operate at. You probably don't need 210 MPH of wind blasting at your painted surfaces. If some dust was in between you and your car while you were using one of those, wouldn't it turn it into a sandblaster?
    Not saying that its bad, but just some things to think about before blasting your car with 200+ MPH of wind.
    WARNING! Eye protection must be worn when looking at my car in direct sunlight. Can cause temporary blindness.
    Jul 2005
    251
    17
    You make a valid point. I think the 210 MPH is measured right at the nozzle. I keep it about a foot or two away, so you could say I am only getting maybe 190-200 MPH on the surface, which is a big difference. LOL.
    I figured if I drive that fast, the leaf blower blowing at 210 Mpg wouldn't really be my biggest issue. (this is a joke)
    Does make you think though and I really can not dispute your point. But my gutt feeling still tells me that I prefer to do it. (for now that is)
    Brad
    Registered Member explore_02xlt's Avatar
    Aug 2005
    156
    16
    got the same one! i love it! lowes, 70 bucks
    Des Moines, Iowa
    40
    5,605
    76
    well worth it!
    Brandon
    Registered Member JG_Detailing's Avatar
    Apr 2004
    Waynesburg, Pa
    48
    1,799
    37
    You could try using this. It's a car blower. I got it from Big Lots.
  1. Car blower
    By JG_Detailing in forum Detailing 101
    Last Post: Mar 6th, 2007, 09:18 PM
  2. Leaf Stains on F-150 Paint
    By 74454Vette in forum Detailing 101
    Last Post: Nov 21st, 2006, 02:00 PM
  3. air compressor instead of leaf blower?
    By 04maxima in forum Detailing 101
    Last Post: Mar 13th, 2006, 05:03 AM
