Can someone tell what they use wool pads for with the G-100?
Thanks
Bryan
Meguiar's does not sell a wool pad for use with the G100, at least not at this time. If you're working on a clear coat finish, chances are very very good that if you use a wool pad on a dual action polisher, while it may remove swirls and scratches, it will leave behind its own scouring marks which then you'll have to remove these.
At this time, the most aggressive products we recommend for use on a dual action polisher are our M83/W-8006 combination. After that it's time to step up to a rotary buffer.
Though I am not proficient at the use of the PC/G100 (got mine over last weekend), I think I know the answer to what your asking about the Wool Pads.
The W7006 Wool Cutting Pads are used for the bonnets added for product removal. My understanding is that these pads are stiffer then the W8006 and W9006, Polishing Pad and Finishing Pad respectively, which are a lot squishier.
Like I said, I did get my PC over the weekend and thus, I am researching like a dog (sniffing out info) learning.
Wool pads are great for removing paint quickly like in a body shop situation when you want to remove your sanding marks. When it comes to detailing cured paint it comes down to user preference.
I personally don't like using wool pads on customer's cars, while Joe aka Superior Shine likes to make his initial cut using wool. Of course this is talking about using a rotary buffer.
But if I am wrong, someone set me straight. Maybe the W7006 is a cutting pad but perhaps not wool.
I can tell you now the 7006 pad is not wool I have it in my hand rite now.
It's my understanding this pad is used with a bonnet over for final polishing, although here in the UK some of the guys had a mini detailing day yesterday and used it with ScratchX.
I think I'll be sticking to the 7006 final polishing with a bonnet myself
Here is the link to the detailing day mentioned above: -
We encourage MOL members to show off their latest before & after results. We also welcome "Work in Progress" Threads. For Enthusiasts or Professional Detailers
You can see the 7006 pad being used
Bryan
Bryan,
Thanks. I think I was too quick on my initial response and after sending it, thought it out and came back with a doubting of my answer.
As I said, I am learning and today I learned to think twice, post once.
Cut ‘N Shine® Wool Pad features aggressive cutting action without leaving typical difficult to remove swirl marks. Removes serious paint imperfections. Quick change Velcro® backing system.
W-7006 SOFTBUFF™ Cutting Pad
Foam cutting action without leaving marks created by wool pads. Removes moderate surface imperfections. Exclusive foam cell structure improves air flow. Quick change Velcro® backing system.
I'd still be abit apprehensive using either without further clarification, I'm still going with the W-7006 pad with a bonnet over for final polishing, better safe than sorry eh
Mike the way your word your posts, it almost seems that Meguiars may be looking at this as a possiblity! lol
Also, how come you don't personally like to use wool on customers cars? You prefer the W700(0/6) or don't like the ammount of marring wool leaves?
Bryan
Quite wise. Discretion is the better part of valor.
Originally posted by Ranger72 Mike the way your word your posts, it almost seems that Meguiar's may be looking at this as a possibility! LOL
I just like to keep the door open to possibilities in all aspects of detailing. I don't expect to ever see a wool pad for use with a dual action polisher, but I also don't close the door on the idea. When we close the door on new ideas we stop learning.
Also, how come you don't personally like to use wool on customers cars? You prefer the W700(0/6) or don't like the amount of marring wool leaves?
I personally don't like the swirls wool pads put into the paint, it's working backwards... you also have to be a lot more careful around high points like body lines and edges. I understand that a lot of guys like wool pads for the speed factor, but I don't do production work, so I don't care about speed. I would rather take longer and work forward in the polishing process than work backwards.
Wool pads are tools just like any other pad and they have their place in your tool box, I own wool pads, I just always use a different tool to do the job.
I agree with you that wool instills more marring, I find that for the most part I only use them after wetsanding. I prefer wool first when wesanding, but sometimes use 84 and a w7000/6.
