I picked up a Clarke 7" Variable Speed Polisher today. I also got a wool buffing pad and a wool polishing pad. My paint job is far from professional and needs a lot of help. I painted the fenders and hood on Tuesday night, 5 or 6 light coats. I can't remember which because I was pooped when I called it a night. As you can see in the picture, I managed to get a nice shine to come through. Before buffing, I wet sanded half the hood. with 220 grit, 1000 grit and 1500 grit I was constantly spraying water while sanding. The Meguiar's products used were #85, #83 and #80. The shine was not there after using all three products in the order listed. I went back and hit it again with #85 and stopped after the shine came back. What did I do wrong ?
I will most likely need to wet sand with 2000 grit or better due to sanding scratches that are still visible. I buffed it out just to see if my hard labor was going to pay off. By the way, the rest of the hood still needs some major wet sanding before I can buff it out.
