What to use under the hood ? { Pic Included }
  • What to use under the hood ? { Pic Included }
    What should I use to clean this ? Its still clean under there but I am noticing this on the hood. I was thinking about getting safe d greaser is that all I need to clean this ?
    I can recomend APC, but I haven't used safe degreaser or an engine compartment yet so someone else might be able to better answer your question.
    You might even try a little soap and water first.
    I want 4" Softbuff pads!
      If you're just looking to clean a small area like that, you could either go with a damp MF, or an MF with some EXTRA! off the shelf. That doesn't look too bad as far as clean-up is concerned.
        That is plastic right? Try APC 10:1 and then some NXT Cockpit Shine or Hyper-Dressing.
