First off, I did read this thread, but I wanted to get some more opinions on the subject. I should receive my Makita 9227c this week and I've already purchased a backing plate and 2 8" yellow pads from a local detail supply store, but now I'm thinking maybe I should return them and just use 6.5" pads on the rotary. My main reasoning is they will be interchangable between my PC and Makita (following the one product per pad rule, of course). Is this good enough reasoning to use 6.5" pads instead of 8"? Is there really a huge difference between the two, or is it really just personal preference? I understand some say its easier to control the 6.5" pads, but I figure that the 8" should be just as easy to use if given proper time to learn. Any experiences or help on this issue is greatly appreciated!
Which size pads do you use?
I use both but most often the 6" pads are my choice. If I have a large surface to do some correction on it's much faster to use the 8 inch pad than the 6 inch. On side panels and curved surfaces the 6 inch is almost perfect in size and easier to work with.Quadruple Honda Owner
Black cars are easy!
8" for virtually everything here
Feels most consistent to me and keeps cabinet clutter to a minimum
For DA use, obviously, I move to the smaller ones, but that's for the different type of machine and the way it operates
Really, it's personal preference on what size you choose. Some don't worry about tight spaces or do them by hand, some use the 6.5 for everything. The results are no different, given identical technique and products.See the big picture, enjoy the details
The larger the pad, the harder it will be to use, the more likely it can cause damage because the edge is moving at a faster speed. Also most cars, unless you have a Hummer have curved panels, having the larger pad doesn't make you buff any faster, if anything it gets really annoying trying to get into some curves.
Originally posted by Buellwinkle
The larger the pad, the harder it will be to use, the more likely it can cause damage because the edge is moving at a faster speed. Also most cars, unless you have a Hummer have curved panels, having the larger pad doesn't make you buff any faster, if anything it gets really annoying trying to get into some curves.My car's so shiny I can see your car's swirls in its reflection.
When I bought my rotary it came with a "no name" 6,5" pad, so that was what I started out with. But from what I know now it was a lousy pad - foam was hard and of bad quality. So when I got some 8" Megs pads, they were so much easier to use! Since then I have pretty much only been using 8" pads. But my rotary can get quite hot sometimes, as it is a compact model actually only recommended for up to 6,5" pads... I will try some 6,5" pads for larger areas, to compare the time used on polishing the surface with different pad sizes. I know the rotary will like the small size better"Now Biff... make sure that we get two coats of wax this time..."
- Back To The Future
