When you guys dress you tires. The next time you wash your car do you scrub the tires clean or just rinse?
Tire dressing
Re: Tire dressing
Originally posted by LT22
When you guys dress you tires. The next time you wash your car do you scrub the tires clean or just rinse?Jeff Smith
Don't mistake my enthusiasm for experience.
I scrub them the tire with a sponge and the rims with a soft britled brush. I use nxt car wash soap in a seperate bucket for the tires and rims, rember to use the seperate bucket so you dont get that dirt in with your normal bucket for the cars body.
Originally posted by Murr1525
If mine look good still, then I try and avoid cleaning them.Jeff Smith
I just wipe with an old sponge... from time to time I will use a brush to remove the build up as Jeff Smith mentioned below.Brandon
2007 Black Chevy Avalanche
My Albums: Avalanche
Originally posted by Shiny Lil Detlr
I scrub them; generally fresh tire dressing won't stick if there is any old stuff still on there; and then you just get it slinging up the sides of the vehicle onto the paint.
But I have reapplied IS over itself probably 2-3 times between thorough washes. But I sprayed lightly directly onto a Tire Swipe. not directly on the tire. I wasn't "that" confident.Jeff Smith
Hey Jeff if you want to lock in that awsome look of HD then you need two cans of clear kote.... just spray and walk away WALA!!!!lol ....make sure its UV resistance....
just kidding bud
im glad you told me that i also recently purchased it but i plan on using endurance for the tires or nxt
i guess i just use HD for the engines and also have you tried using it on the interior or is it not recommend for example your dash board or rood lining....Miguel
"What you become directly influences what you get"
just kidding bud
So I have neglected the interior pretty much for about a month and a half or so. The last time all I used was Cockpit shine. and the Gold class Leather cleaner/conditioner, and the NXt glass cleaner on the interior. But I do plan to use the HD on the interior and will probably use in the enigine bay. I just want to make sure I am happy withthe protection on the ouside before I get sidetracked on the inside. For the outside, I still have the grill to detail out and protect and will then likely work torward doing away with the scratches on my composite bed. Then to interior will come after that.Jeff Smith
As you scrub the tire during the wash how much does the gloss tone down? I'm going to be using the Endurance High Gloss and I and want the gloss to last after washes, so should I just rinse them?Brandon
