Those dang spots....
Results 1 to 10 of 11
Thread: Those dang spots....
    Grill Master kellyinkc's Avatar
    Jul 2005
    1,597
    30
    Hey I looked at my hood tonight with a photo loupe. Had to use a flashlight but what I saw was like "glowing white dots". Almost looked like I was looking through a telescope. They are round.
    Any ideas. Thanks
    Kelly
    Registered Member Jeff Smith's Avatar
    Jul 2005
    53
    1,254
    27
    Re: Those dang spots....
    Any ideas. Thanks
    Kelly
    Would it look like the pics from this post?
    http://meguiarsonline.com/forums/sho...&threadid=9313
    Jeff Smith
    Don't mistake my enthusiasm for experience.
    Jul 2005
    1,597
    30
    Kinda. Can't feel a thing.Can't tell if they are pits or contaminates. I've clayed SX etc. Bodyshop said it was solvent pop. Not giving up yet. tried a pic but you have to get right on the paint. In fact I had the loupe almost on the hood, like less than a half inch. All I have so far is an 7" Craftsman orbital.
    Do have 83 and 80.
    Kelly
    Jul 2005
    53
    1,254
    27
    Do have 83 and 80.
    Kelly
    Mine are only visible under certain lighting conditions. I suspected some sort of splatter from a chemical or something at a dealer. I hit mine with the PC with several polishes. The most agressive was #80. As the thread explains, they actually appeared to have gotten worse the further I went so I stopped.
    I am not going to recommend you trying anything as I was unsuccessful. Maybe some pics would be best. Some of the others might be able to point you in the right direction.
    Mine appear to be under/in the paint and are above my current skill level to remove. I am hoping that later I can revisit this issue once I have gained a bit of skill with my rotary.
    Unfamiliar with the Craftsman Obital. Maybe someone more familiar can clue ou in as to whether or not it has enough "umph" for defect removal like this.
    Best of luck on this. I know where you are coming from
    Jeff Smith
    Jul 2005
    1,597
    30
    Thanks seems like it is under the CC. By rubbing with hand it seems under my fingers. So next time I look for a car I'm taking my QD and clay and spot clay the car I'm looking at. Dealer might think I'm weird.
    Kelly
    Okanagan Valley, BC
    4,544
    393
    Hey Kelly,
    If it is solvent pop, then it is in the paint and not on the paint. Basically, solvent pop can occur from improper paint prep or improper painting methods. If it is indeed solvent pop, I would need to see a picture of your spots to be sure, but if it is, buffing will not help that much.
    Until we are certain it is solvent pop, try using ScratchX on a piece of 100% cotton toweling. Work on a small area and then check your results. Using ScratchX by hand with the cotton toweling will probably be more aggressive than using the Craftsman orbital.
    Please keep us posted!
    Tim
    Jul 2005
    1,597
    30
    Thanks will do. Will my orbital work with 80? It says by hand???? or orbital. I have terrycloth bonnets to apply.P;us a wool-syn blend polishin bonnet. I like to wipe off by hand. Kinda blending old and new together. Am I assuming that 80 is like DC12 put together. Is dry buffing recommended after wax is wiped off or am I risking swirls?
    Kelly
    Okanagan Valley, BC
    4,544
    393
    Hey Kelly,
    Yes #80 will work with your orbital just fine. Meg's #80 can be used by Rotary, DA, Orbital or by Hand.
    Tim
    Jul 2005
    1,597
    30
    If I use it by hand how much elbow er.... passion do I need.
    Kelly
    Okanagan Valley, BC
    4,544
    393
    Hey,
    Use enough "passion" until it is a light residue. Then remove will a MF towel.
    Tim
  1. Dirt Spots/Water Spots after Rain
    Last Post: Sep 30th, 2008, 10:29 AM
  2. spots
    By BLACKHAT04 in forum Detailing 101
    Last Post: Apr 22nd, 2007, 01:51 PM
  3. 06 TR GTI first detail, DANG !
    By cv_soccer in forum Show Off Your Latest Detail Work
    Last Post: Apr 15th, 2007, 05:35 PM
  4. It’s about dang time!
    By the other pc in forum The Break Room
    Last Post: Jun 5th, 2006, 04:33 PM
  5. Dang thief's
    By Desertdawg in forum The Break Room
    Last Post: Nov 18th, 2005, 09:15 PM
