Please - what can be done once wax has been rubbed into rubber bumpers, etc.? Thank you.
Removing wax from rubber/vinyl
Thank you, Hannibal. I am using
Megniar's Cleaner Wax. I wil try the Simple Green and brush approach. The wax is embedded in the rubber. It has been there for months. (Don't say it). This is due to a grossly erroneous theory that because the non-metallic parts of the car appeared dry, the wax might seal it. (Don't say it).
But in keeping with outlandish theories, now that the rubber has deteriorated further, and I'm calling roof-rack, etc., 'rubber', while it is probably a synthetic blend, and as putting oil on it would create a temporary cosmetic effect, but otherwise make a bad situation worse, what might be done? Thank you.
I like to use rubbing alcohol on a microfiber towel. Just rub the towel into the rubber, and you will see the transfer back to the towel after a bit of elbow grease. Then apply a suitable dressing. I like #38 Tire and Trim Gel. Insane Shine or Tech Protectant works good too.
I have back to black for trim until I try meguiars Gold CLass trim dressing. It works great!!
Good Luck!!!
if you get a chance use the search feature try different wording....but there are many ways you can clean and try removing the wax off rubber seals or gaskets...one example is #40 ,#39, #38, triple duty brush from meguiars
or try your own tooth brush cut to size for stiffer bristle (may work)
vinly & rubber cleaner/conditioner
Heavy Duty Vinyl Cleaner
Tire & Trim Dressing Gel
triple duty brush
hope this helps....Miguel
"What you become directly influences what you get"
I have to say the creamy Peter Pan peanut butter worked like a charm. It was a little messy but too off the white residue fairly easily.
I would be interested to know what might be in peanut butter that would remove the wax. Any chemical engineers out there?2000 Nissan Maxima
2005 Nissan Xterra
Yes I am chemical engineer.. and I have no idea.
Did it seem to dissolve the white stuff, or just kind of lift off flakes?
Like dissolves like, so could just be a similar oil in the wax to peanut oil.
Anyway, The Gold Class Trim Detailer certainly seems to work well for me on rubber/plastic bits. You can apply the trim dressing, then wax, then remove the wax and excess dressing. It will help protect from getting white residue.2017 Subaru WRX Premium - WR Blue
I think the peanut butter trick, like many of these solutions, simply works by soaking the residue with oil, rendering it more transparent, and therefore temporarily invisible. As the oil is removed by weathering/washing, the stain will come back.
The only way to truly remove the wax stains is to mechanically agitate (brush or MF) in conjunction with a solvent/emulsifier (either a detergent, like the Simple Green that was mentioned, APC, #39, etc., or with a dressing). After you have it removed, you want to be very careful so as not to get it on there again, because it is *so* much easier to take a little more time and not get it on there in the first place than it is to try to get it off.
