i just got a 93 firebird and the paint is very neglected the clear coat look like it has chips missing out of it the hole car look that way so how can i get it out or do i have to repaint it
very neglected paint
Welcome. If the clear has failed then there is little you can do to bring it back. On this forum, pics are very important since its quite dificult to describe what you see. If you can get some pics then someone will be in a better position to give advice. Thanks.
Welcome!!! You would be amazed at how much better that paint will look if you follow the meguiars system.
As sweetjazz posted pix are important for a better opinion on a solution to a problem. If the clear is chipped ,allegated or otherwise compromised you know that a repaint is in the future. Your current use of the vehicle is a factor as well as where it is parked( inside or outside) especially in Michigan during the winter.Death Before Dishonor
