Wrong compound used, not sure what step to do next.... Clear coat looks burned.
Re: Wrong compound used, not sure what step to do next.... Clear coat looks burned.
Originally posted by muslenutz View Post
This has happened many times in the past. Depending on how severe scratches are, most of the time one can have success with our G17216 Ultimate Compound. If working by hand, we would suggest applying with a soft foam applicator pad, like our W0004, or a microfiber applicator pad, like our X3080. Work in small 1 square foot or so sections at a time, keeping your hand flat, and work the product in circular motions with moderate pressure for about a minute or so. Wipe off. You can repeat this as many as 4 or 5 times in any given area, but beyond that, if the scratches remain, it will take a machine, like a dual action polisher.Nick Winn
Irvine, CA
nawinn@meguiars.com
I imagine I should probably pick up a polisher as I get into this as a hobby. I’m just a little nervous to make it worse using one. Do you have shortcuts to a link on using polishers and two stage detailing. It would help if you do as I am away from a laptop. (Phone screen is small on this site)
Here are a couple of references to get you started.
First, an older article by Mike Stoops.
D/A Buffing 101 - An Introduction to the G110v2 (and similar)
A video by Nick Winn
How to Polish like a Pro with Meguiar's MT300 and Ultimate Products(Quick Tips Video)
Originally posted by muslenutz View PostI imagine I should probably pick up a polisher as I get into this as a hobby. I’m just a little nervous to make it worse using one. Do you have shortcuts to a link on using polishers and two stage detailing. It would help if you do as I am away from a laptop. (Phone screen is small on this site)
These are both great. Thank you! After looking at my photos what pad and what material would you use? My goal is to remove the swirls and scratches without destroying the clear. The car is a 2018 and the owner before me loved car washes so there is lots of swirls. I want to remove swirls and containment’s, polish to enhance the shine and wax to protect it.
