I typically use the standard store bought clay kit but went for the Professional Mild clay from Amazon. The clay worked great at removing bonded on contaminants but after I was done, I noticed my paint was marred. My paint is a little on the soft side (2012 G37 pearl white). The marring is on the light side and can only be seen in bright lights at certain angles.
What is the fastest and easiest solution to remove the marring?
Thank you.
Thank you.
