Just newly registered and love Meg's products. I joined up on a recommend by the F-150.com forums gang. Kudos to them.
As you can see, (link below) I have the classic acid rain etch, on my hood.
A 2005, Ford F-150 less than 10,000 miles, sits outside 24/7. The rest of the paint is in good shape--clayed, including a coat of #20. I've also done the Rx plus sections which is a fantastic point of reference. Thanks Megs.
I do have a Porter Cable G-100/7424 I'd like to use on the etch. But frankly, I do not know if PC will do the trick without experience using it or knowing which type of pads or products to use. Again, I've never used a DAP
Using the Megs forum thread research, I understand I am to start with the least volatile product and work my way up, starting with the Scratch-X. However, and noting, the problem again lies with the entire hood--reading that Scratch-X is for spot on removal. I understand I can use the DA with the Scratch-X but since this is such a large area I'm wondering if the Scratch-X is the right choice for a starting point abrasive.
Thoughts?
Thoughts?
