Topping NXT aka "How to top one type of wax with a different type of wax
There is always a lot of talk about topping NXT with other products, because this is a popular topic, I thought I would offer this simple suggestion.
If you think you would like to apply a topper over NXT, before you apply your choice of a topper over the entire finish, first do a side-by-side comparison and inspect your results carefully to insure that the test area does in fact look better than NXT by itself before applying your choice of topper to the entire finish. If you apply your choice of a topper to the entire car without comparing, you will never know if it improved or diminished the results created by the NXT alone.
Here's how to do a test spot,
First - Wait until you have two thin, uniform applications of NXT Tech Wax over the entire finish. Two thin applications always look better than one application.
Second - Find a nice flat panel like the hood or deck lid so that you can look down on the finish while standing over it. Apply your choice of a topper to a square section about one foot square being careful to do so in a way as to have a very distinct section with only the topper in this section. Allow the topper to dry according to the instruction and the remove with a microfiber polishing cloth or a clean, soft 100% cotton terry cloth towel. To be fair, you should apply a second coat in this same section to insure a uniform application. Again, apply and remove according to the product's directions.
After you applied and removed your choice of a topper carefully, inspect the two areas under different lighting conditions. Different lighting conditions will allow your eyes to see the different dimensions of your finish, such as richness, gloss, shine and clearness or clarity. View the two areas from different angles, from directly overhead, and with a light source centered in the area, like the sun. You may also want to have some friends compare the two areas also, a second set of fresh eyes may see something you miss, especially after you've been working on the finish and staring at the paint for hours.
If after doing this side-by-side comparison test in one small area, your eyes will tell you whether or not you want to continue with applying the topper to the entire finish.
Hope this helps...
Hope this helps...
