Wheel Brightener Questions
Re: Wheel Brightener Questions
Originally posted by STG View PostI've been using Gold Class All Wheel Cleaner on my polished aluminum (painted center section) wheels with absolutely no problems. In my opinion, it's the best wheel cleaner Meguiar's makes for bare aluminum.
2005 Toyota Camry LE Phantom Grey Pearl
2001 Toyota Corolla LE Silverstream Opalescent
1996 Lexus ES300 Ruby Pearl
Seems to me I remember reading somewhere WB is something you want to use on a fairly dirty wheel, not light dust as its quite strong.Brandon
2007 Black Chevy Avalanche
My Albums: Avalanche
Originally posted by Mayur View PostWill strip wax off wheels if diluted 4:1?
I understand it stains polished aluminum. I have a polished lip, is there a dilution rate I can use that wont stain it and still not strip the wax?
Thanks
Mayur
If you insist on using Wheel Brightener then a 10:1 dilution is about as strong as I'd go for this particular use.Michael Stoops
Originally posted by Mike-in-Orange View PostIf you insist on using Wheel Brightener then a 10:1 dilution is about as strong as I'd go for this particular use.2005 Toyota Camry LE Phantom Grey Pearl
Most cleaning chemicals will act to remove and not add-to a previously applied layer of anything. The act of rubbing a wheel brush or a wash mitt against the surface of anything with a coating of wax will tend to remove the coating of wax, not add to it.
I use Wheel Brightener all the time, but only on coated rims, I use it at 4:1 but that will strip off wax as it great for break dust and is pretty stout stuff. I give it a spray, agitate it, and rinse it right away. As Mike in Orange recommends, try 8:1 or 10:1 and see if how that works out for you. Not sure I would use it on Aluminum wheels...
Tom
