hoping someone could help me out with a few thing...
this is basically my first time buffing/polishing
my setup PC
2.0 cutting pad
2.0 polishing pad
2.0 finishing pad
m80
deep crystal polish
and yellow 16
so i started out with the cutting pad and m80 and it definitely did what i wanted it to do and that was remove all the swirl marks. they were really bad. i apply some of the m80 to the pad then spread it around without it on, then turn it on and make a quick pass. then i work it in with slow passes for about a minute in a 16x16 area on setting 5. does that sound correct?
anyway here are my questions
1. i still have some scratches in the paint, they look like regular clear coat scratches cause there is still black paint under it. SO what would be a stronger polish? or would a different approach do it?
2. i am assuming i use the deep crystal polish with the polishing pad. is that correct? i did this and it left a haze..this was on setting 5
3. i use the wax with the finishing pad right?
4. what is this and how do i get rid of it? the pics look like its just primer but if you look at it in person it looks like its just the clear coat thats like that.
BIG THANKS IN ADVANCE
my setup PC
2.0 cutting pad
2.0 polishing pad
2.0 finishing pad
m80
deep crystal polish
and yellow 16
